crystalyte 3540 axle failure
Postby wojtek » Sun Mar 04, 2012 11:10 am
it just broke during riding my velomobile Go-one Evo... it lasted for 2 months - how sad :(
the motor was modified by Farfle. In order to accomodate the larger wires, he must have drilled out too much from the axle and made it too weak..
Just a warning not to overdo it...
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Re: crystalyte 3540 axle failure
Postby Farfle » Sun Mar 04, 2012 1:21 pm
Ouch... My hypothesis is that the new crystallite axles are a very poor steel. I had to make a new one for another sphere member who had a similar problem. His is made of stressproof rod in the exact same shape, and AFAIK has worked fine so far. If you have access to a press, I can send you a new axle for the cost of shipping.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby NeilP » Sun Mar 04, 2012 1:29 pm
Farfle...are the splines on these motors the same as the 53xx series motors or are they smaller?
Can that 53xx series shafts also bee pressed out?
Do you know if that particular size / design of splines is an off the shelf size of splined shaft that can be purchased as stock splined steel shaft or do you have to machine the splines your self?
I want to make myself a new axle, for my 5304 and do not like the idea of using a keyway/woodruff key. I do not have the ability to create a splined shaft, but if I can get the stock splined steel, I can turn the axle down as I require
If it is available, do you perhaps have a supplier and or part number for that type shaft.
Thanks
Neil
Mongoose frame, Fox F100 forks,26x2.3 tyres
180mm disks
100V 20Ah LiPo
Lyen 18 FET 65 Amp,5304 in 26 inch Mavic rim
To illustrate the vain conceit that the universe must be somehow pre-ordained for us, because we are so well-suited to live in it, he mimed a wonderfully funny imitation of a puddle of water, fitting itself snugly into a depression in the ground, the depression uncannily being exactly the same shape as the puddle."
-- Richard Dawkins, in "Lament for Douglas" (14 May 2001)
NeilP
Postby Farfle » Sun Mar 04, 2012 1:54 pm
No, the X5's are not the same size as the hx axles but yes, they can be pressed out. They are not a splined shaft, you use a linear knurling tool with coarse teeth, I bought this one: http://www.grizzly.com/products/2-pc-Kn ... -Set/H5936
and it held up for about a month until it wore out, but it's 1/10th the cost of a good one.
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby rojitor » Sun Mar 04, 2012 2:01 pm
I was thinking about dremeling mine... I will keep in mind your advice
rojitor
Postby wojtek » Sun Mar 04, 2012 2:13 pm
thanks a lot for your offer and sharing your experience, Farfle!
a new axle would be fantastic, im happy also to pay for the material and your time..
wojtek
Postby NeilP » Sun Mar 04, 2012 2:21 pm
Farfle wrote:No, the X5's are not the same size as the hx axles but yes, they can be pressed out. They are not a splined shaft, you use a linear knurling tool with coarse teeth, I bought this one: http://www.grizzly.com/products/2-pc-Kn ... -Set/H5936
Not come across that before. so how does that work? I imagine you stick the workpiece in teh lather, rotate very slowly and apply the tool against the workpiece with pressure to create the 'splines' on the shaft...but then what...you just press the shaft into a slightly under sized hole I guess?
maybe you heat the rotor a bit first to expand the metal? before pressing the shaft in,
So it is almost just a friction fit with a bit of knurling on the shaft as opposed to a proper keyed fitting. Would not have thought it would have been enough..
180mm disks
100V 20Ah LiPo
NeilP
Postby neptronix » Sun Mar 04, 2012 3:34 pm
On the plus side, you did a great job on preventing the axle from rounding out the dropouts :mrgreen:
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby NeilP » Sun Mar 04, 2012 3:42 pm
That is a scarely thin axle...what remains of it after it was drilled out. Hardly any axle left, surprised it lasted for more than one or two runs down the road
Looking closely at the fracture surface, looks like it has two fractures in it. Older one initially cracked but axle hung on for a while, started rusting then it cracked again failing totally at a later date.
180mm disks
100V 20Ah LiPo
NeilP
Postby MadRhino » Sun Mar 04, 2012 3:50 pm
I had an X5 axle failure, and it wasn't even modded. The H series axle seem stronger to me, but its smaller size doesn't let a lot of room to enlarge the channel. I dremeled mines, and they are holding well riding hard off road.
Norco A-Line, 50+ Mph dirt bike and winter commuter... sold
Specialized Demo 8 performance dirt bike
http://img715.imageshack.us/img715/5824/dsc03417ae.jpg
Santa Cruz Heckler, lightweight road racer
Santacruz V-10, performance dirt bike
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby NeilP » Sun Mar 04, 2012 4:01 pm
I have been considering a torque plate with a 'metalastic' type fitting, you know what I mean? something to still prevent axle rotation but with enough give in it to take out these shock loadings that are probably a contributing factor on these failures..or just thicker axles I suppose
180mm disks
100V 20Ah LiPo
NeilP
Postby The Mighty Volt » Sun Mar 04, 2012 4:10 pm
the more and more I read about the "new" Crystalytes the less impressed I am.
The Mighty Volt
Postby MadRhino » Sun Mar 04, 2012 7:21 pm
NeilP wrote:I have been considering a torque plate with a 'metalastic' type fitting, you know what I mean? something to still prevent axle rotation but with enough give in it to take out these shock loadings that are probably a contributing factor on these failures..or just thicker axles I suppose
I've been thinking about torque absorber axle mounts to replace the dropouts, but this would make servicing longer and I like to swap the motor wheel on my bikes. So far, I found that thick and tight fit dropouts are safe for the axle.
Work in progress:
Trek Session 10
Fatboy
MadRhino
Postby sn0wchyld » Mon Mar 05, 2012 1:53 am
:shock: :shock: :shock:
FFS. just another issue with these motors to worry about. Granted though, looks like there was allot of material taken out, to close to the point that the axle narrows to the 12x10mm threaded part. where you doing anything in particular when the failure occored? I'm worried now since with the MX rim/tire ive started riding much harder off-road than before :evil:
send you a pm farfle, i'd be interested in a new axle too, obviously happy to pay for your time etc etc.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby wojtek » Mon Mar 05, 2012 2:38 am
i was just riding on a road ..
wojtek
Postby Spicerack » Mon Mar 05, 2012 5:46 am
I reckon the only way to go is a bigger axle but if not, then rifle drill the whole xle and run wires through each side.
The axle needs to be drilled in a lathe so it's perfectly central- looks like this one may have been drilled offset. Looking at Farfle's 2Pi effort I don't imagine a new 3540 axle will be much of a challenge....
Norco Shore2
Was Cellman MAC rear oil cooled now 8x8 9C vented and temp probed
12 FET controller
62V 18650 home made battery pack
50 km/h
http://endless-sphere.com/forums/viewtopic.php?f=6&t=32769
Repair thread http://endless-sphere.com/forums/viewtopic.php?f=2&t=34806
Oil cooling the hubbie http://endless-sphere.com/forums/viewtopic.php?f=2&t=37972
Spicerack
Postby miro13car » Tue Mar 06, 2012 4:00 pm
This axle is dangerously thin was asking for trouble
miro13car
Postby electricwheels.de » Wed Mar 07, 2012 7:25 pm
Here's a model of an axle for the H-series motors
H motor new axle
(80.49 KiB) Downloaded 4 times
and a top view on to the assembled gear...
Top view of assembly
(97.72 KiB) Downloaded 4 times
Runs with larger bearings dia 42 x 20 x 12 mm, so sidecovers would need machining.
Take a close look at the axle. The thread is M14 x 1.5 mm. Where it sits in the dropouts, its been machined out to 10 mm width, with one side being a radius of 5 mm. That way it sits centrally in the original dropout slot, has a 'flag' but would need a torque arm fitted.
I've got the whole motor, original and modified, as models on my computer. Production drawings are made. Shame it's too expensive to have them made.
If anyone is willing to produce the parts, I give the drawings away for the cost of 2 sample sets :wink:
electricwheels.de
example how cheap becomes expensive
Postby miro13car » Wed Mar 07, 2012 10:40 pm
Wondering what would be the cost of such rebuilding of HS/HT motor presuming you don't pay for drawings, charging US$50 labour rate and and material easy US$ 1000 I would say but I think much more maybe 1500.
Only taking such motor apart with Chinese using thread locker compond is a challange and time consuming and their choice of Philips screws for cover is complete ignorance , because standard screw for such application is Allen bolts , well but they cost cents each more.
Machining new axle is only beginning of mods, reboring and replacing bearings is another mod, next replacing halls with quality ones, after that what else
China manufacturing is obssesed with cost savings?
Such modified HT/HS is not exactely cheap anymore,
miro13car
Re: example how cheap becomes expensive
Postby wojtek » Thu Mar 08, 2012 3:11 am
miro13car wrote:Wondering what would be the cost of such rebuilding of HS/HT motor presuming you don't pay for drawings, charging US$50 labour rate and and material easy US$ 1000 I would say but I think much more maybe 1500.
IF done correctly in first place in chinese factory, the price would rise insignificantly..
This is exactly the case we were raising with Kenny re 54xx order. He promised to do upgrades and raised the price but not much at all.
The labour normally is the same, it is only about using higher quality materials..
China may be great to produce cheap products IF you tell them exactly how, and run strict QC, but if they come up with their own products, they build and design, they are normally not impressive.
wojtek
Postby John in CR » Thu Mar 08, 2012 11:12 pm
It just goes to show that there's no shortcut that enables big power and low weight in a truly reliable hubmotor. If you cyclist weight guys are breaking axles, imagine what it requires to power fat ole me, and to make matters worse in hardtail.
John in CR
Postby Spicerack » Fri Mar 09, 2012 2:16 am
Why do you comment John, got a better motor to offer or something? :wink:
Norco Shore2
12 FET controller
50 km/h
Spicerack
Postby wojtek » Fri Mar 09, 2012 4:14 am
i still think heat is the main problem for hub motors..
but there are geniuses out here in ES already doing the liquid cooling and pulling huge A with no overheating issue.. so the weight to power ratio with cooling system is getting quite impressive..
wojtek
Postby miro13car » Sat Mar 10, 2012 8:10 pm
you forgot cooling system with liquid weights also , right?
There something wrong with hub motor needing cooling at even 2000W.
There is something wrong with the motor which simply needs to draw so much power, to much power to reach say 35mph comparing with other motors .
So the question should be why it needs to draw so much to produce?
miro13car
Postby wojtek » Sun Mar 11, 2012 4:36 am
miro13car wrote:you forgot cooling system with liquid weights also , right?
the weight penalty for adding cooling system is nothing comparing to the results it gives !!! Look here
viewtopic.php?f=6&t=26029&start=195#p530781
wojtek
Next
Return to E-Bike Technical
Who is online
Users browsing this forum: Gator, Mateo Electric and 8 guests
