motomech wrote:As an Ex Japanese motorcycle mechanic, my favorite sealant by far is the gray, semi-drying, non-silicone based stuff sold by the manufacturers.
Various names, Hondabond, Yamahabond, etc.
All the same stuff and it's perfect for that application.
gogo wrote:motomech wrote:As an Ex Japanese motorcycle mechanic, my favorite sealant by far is the gray, semi-drying, non-silicone based stuff sold by the manufacturers.
You'd think there would be "improved" stuff by now, but you're right, Yamabond worked great on motor side covers and gearcases.
andynogo wrote:I rode it to work today, which is 22km. The hottest it got was around 90 celcius. It was very interesting to see the temperature on the windings go up by a degree or two a second whilst accelerating from standstill, then drop almost as fast once up to speed and on WOT. Most of the time it was running at 75 celcius.
auraslip wrote:What I take from this is that we need to find out what type of neo magnets they use to make these hubs! Until then, I think I can hang out in the 80c zone. With my air ventilated 9c I get it up to 120c pushing 4kw. With my new H series clyte in an oil bath I think I can do 4kw and stay at or under 80c.
edit: I just had one more thought: does the irreversible damage stack? As in at 100c you have 2% damage. If you take it to 100c again, do you get 2% MORE damage?
johnrobholmes wrote:More than likely the cheapest grade N magnets are being used. Otherwise there would be some boasting of the grades used. Probably N35s.
auraslip wrote:This is my idea for a vent hole.
The little plastic tube fits onto a nipple. Then the tube loops around the axle so that the spinning of the axle should spin any fluid back towards the opening.
fechter wrote:auraslip wrote:This is my idea for a vent hole.
That looks like it would work (but I think you show the wheel direction backward - I get the idea). The tube might even fit inside the cover. You could use 1/4" copper tubing and a 90deg compression fitting at the end.
The open end should probably be closer to the axle than the place where it comes out so centrifugal force will help push the oil back to the motor.
dfar wrote:you can purchase a couple brass fittings...
teklektik wrote:
(BTW - How about posting pics [in-line] instead of just as attachments? ...much easier to view...)
dfar wrote:I was not aware I could do this, could you direct me to where I could learn to do this?
motomech wrote:Why not put a couple very small vent holes inside the threaded portion of the free wheel mount and let them continually lube the DNP POS
Users browsing this forum: Google [Bot], pacamu, raveruk1 and 6 guests
