dfar wrote:you can purchase a couple brass fittings...
teklektik wrote:
(BTW - How about posting pics [in-line] instead of just as attachments? ...much easier to view...)
dfar wrote:I was not aware I could do this, could you direct me to where I could learn to do this?
auraslip wrote:
This is my idea for a vent hole.
The little plastic tube fits onto a nipple. Then the tube loops around the axle so that the spinning of the axle should spin any fluid back towards the opening.
motomech wrote:Why not put a couple very small vent holes inside the threaded portion of the free wheel mount and let them continually lube the DNP POS
andynogo wrote:My concern with a sintered bronze fitting is that the oil will wick through the sintered bronze and leak more than a tube or small hole as previously described. Remember the KISS principle people
GCinDC wrote:i'm thinking 150C is the absolute limit, for the halls, varnish etc. i have the sense that the oil will take the motor much longer to heat up, but eventually it will get hot, and probably stay hot.
bigmoose wrote:It is good to see more people discover and document the benefit of oil cooling a hub. I predict it will become the standard in the near future.
Pioneering work was done in this area by Bowling Green State University (BGSU) Professor Anthony Polumbo in BGSU Paper "PowerDenseElectricMotor-BGSU-01566299" (0-7803-91 45-4/05/$20.00©)2005 IEEE) where they increased the power of a NEMA 215 Frame induction motor used to power a bus from approximately 10Hp to 100Hp. Not all the improvements were from oil cooling, but it sure enabled much of the increase in "Power Density."
Sadly the Electric Vehicle Institute at BGSU has been dismantled and the staff scattered... right when we on the cusp of electric propulsion. They had a great staff and great vision, just too early for stable funding...
GCinDC wrote:... as the seal on the disk side blew and a bulb of oil appeared.
GCinDC wrote:... if oil covered my vent hole, there would be too much pressure in there.
Users browsing this forum: Sancho's Horse, Supertux1 and 9 guests
