Hi, I have a golden motors magic pie which has been changed from wye to delta.The internal resistance has dropped from 216 milliohm to 65mmilliohm. New hall positions have been set up with a scope. The hub has 4 internal fans with heavily drilled side plates and 8 guage phase wires. the motor runs sweet It pulls about 240watts free rpm on the cycle analyst doing 80km/hr with a 470mm diameter motorcross tyre on a 14"rim(wheel off the ground). But with the EB224-asi 24 fet controller the motor surges/hunts and cuts back the current to approx 3500W. For a couple of months i have had to stick with my 12 fet it runs great but with only 3100w (the controller gets very hot of course) but when i swap it back to the 24 fet it current limits and surges. When it does run up to 5000w it feels great, with heaps of torque and is a great ride. I have tried another 24 fet controller(thanks toolman2) but with the same surging problem. Battery pack is 20 A123 cellls = 66V 20AH. What is happening? How can i fix this? Software? Inductors on the Phase wires? Please use small words i am more mechanical than electrical.
Thanks Guy
