by number1cruncher » Thu Apr 12, 2012 11:23 am
I think they are the jumpers for regen (BK-to-GND) and cruise control (CR-to-GND). I would connect one set at a time to see if it is either regen or cruise control. That should resolve that issue for you.
As for the control modules, I would expect to see three wires coming out of the controller for X1, X2 and GND to select L-H-M. Not sure how to wire that cruise module. I just connect the jumper on mine. In programming you can select the amount of seconds you hold the throttle steady that locks the desired speed. Hitting an e-brake or rolling the throttle breaks the signal.
Go to
http://www.ebike.ca and buy stuff to support the rEVolution!
GT Aerostream 700c w/ Gates Belt Drive, Rear Nexus 3 Speed Hub, Front 9C stock 36v10ah LiFePo4 - Gave to my dad
Electra Townie 700c Euro 8i 12s3p Zippy LiPo - Dented rear rim on monster pothole, temporarily out of service
Electra Townie 26" 3i w/ 9C Lyen 4130 12 FET 18s2p Zippy LiPo
All things lead to the path of least resistance.
"Political correctness is tyranny with manners." ~Charleton Heston
