http://www.ebikessf.com/node/202 Only $300 for the H series motor too. Best deal I could find.
here's a picture showing the wiring harness. Yes they use bullets here. me gusta. (still have to upgrade the wiring though. Looks like 16 awg)
I think that we may be mixing metaphors here, so to speak.migueralliart wrote:When the temp is normal the thermistor is passing ground thru the connection and when it heats up is is essentially a switch that opens (cuts) the ground connection.
auraslip wrote:Can anyone wax eloquently on the difference between a two wire thermals sensor and a three wire thermal sensor?
GCinDC wrote:no cat background?![]()
auraslip wrote:I'm currently using an lm35 powered temp sensor.
Is there any advantage to it? Perhaps easier to create a digital read out with it? Something tells me it should be fairly easy to do.
ebikes-sf wrote:2000 ohms @ 25 °C
2417 ohms @ 50 °C
3392 ohms @ 100 °C
4280 ohms @ 150 °C
GCinDC wrote:interesting to see they added a 4th slot.
GCinDC wrote:btw, the LM35DZ is a bit fat, but will it work fine? should attach the hall + to the +Vs and NOT the Vout?
ps. i'm curious about your avatar. what's the story about it?
GCinDC wrote:and of course the bearing stayed on the axle, and my gear puller claws won't fit, so i might trim them back to the lines i drew.
amberwolf wrote:If you pull on that outer race the bearing will likely be damaged. You want to only pull on the inner race, because that's where it's connected to the motor...
Users browsing this forum: CNCAddict, Google [Bot] and 15 guests
