china controller 60v 1500w wiring diagramm
Postby moritzerl » Sat Apr 21, 2012 1:30 am
Hello guys
Do you have a wire diagramm for this controller ?
http://www.ebay.de/itm/60V-1500W-Brushl ... 1010535033
Our do you have a link to the manufacturer ?
I have really problems to get it run.
Cant find the throttle control cable and dont know how to
connect the reverse cable
Thanks
moritzerl
100 µW
100 µW
Re: china controller 60v 1500w wiring diagramm
Postby John in CR » Sat Apr 21, 2012 11:28 pm
The picture in near the bottom of the Ebay listing seems pretty straight forward despite the confusing number of wires.
For the throttle, first distinguish between the connector for the throttle and the one for the 3 speed switch, since the descriptions by the Chinese are lacking. The throttle will have a single wire at +5V, a ground, and typically in the middle is the sense wire. The 3-speed will show a 5V differential across 2 of the combinations with the 3rd wire.
Reverse is simple. It's just 2 wires that you wire a switch across. Completing the circuit is reverse (usually speed limited to something like 30% and open circuit is forward.
John in CR
Return to E-Bike Technical
Who is online
Users browsing this forum: chvidgov.bc.ca and 12 guests
