Ref: http://www.umich.edu/~arclab/max/media/gyrovehicle.pdfThe dynamic stabilization of a monorail car or two-wheeled automobile requires that a torque acting
on the car from the outside be neutralized by a torque produced within the car by a gyroscope. The
gyroscope here is used as an actuator, not a sensor, by using precession forces generated by the gyroscope.
When torque is applied to an axis normal to the spin axis, causing the gyroscope to precess, a moment
is produced about a third axis, orthogonal to both the torque and spin axes. As the vehicle tilts from
vertical, a precession-inducing torque is applied to the gyroscope cage such that the resulting gyroscopic
reaction moment will tend to right the vehicle. The key idea is that motion of the gyroscope relative to
the body is actively controlled in order to generate a stabilizing moment.
d8veh wrote:Be careful, you might find that you can't turn. I think you need twin gyros to stop rolling but still be able to steer.
Here's a link to that motorbike that can't fall over.
http://www.youtube.com/watch?v=bWxRV4jZ ... re=related
Miles wrote:It won't work with a rigid set-up.... It's a bit more complicated than that....Ref: http://www.umich.edu/~arclab/max/media/gyrovehicle.pdfThe dynamic stabilization of a monorail car or two-wheeled automobile requires that a torque acting
http://www.endless-sphere.com/forums/vi ... 29#p465729
http://www.endless-sphere.com/forums/vi ... =7&t=31949
Indubitably wrote:The other, far less exotic, complicated, expensive, and functional, alternative is just to buy a complete swing arm chain drive rear end from a generic chinese mini atv. The wheels wouldn't have independent suspension, and I wouldn't be doing any rear wheel steering, but it probably would be lighter, have a differential, and if/when it died, I would be able to more less just straight up swap the whole thing out for another rear end instead of hunting for rare replacement parts and the like.
AussieJester wrote:Indubitably wrote:The other, far less exotic, complicated, expensive, and functional, alternative is just to buy a complete swing arm chain drive rear end from a generic chinese mini atv. The wheels wouldn't have independent suspension, and I wouldn't be doing any rear wheel steering, but it probably would be lighter, have a differential, and if/when it died, I would be able to more less just straight up swap the whole thing out for another rear end instead of hunting for rare replacement parts and the like.
Pretty sure the rear ends are solid axle no diff..
KiM
AussieJester wrote:^^^Came across the exact diff when i was building trikes, they are for ride on lawnmowers apparently, they
also come in differing lengths and axle size, i have a link somewhere to a place that stock them all..
KiM
Indubitably wrote:AussieJester wrote:^^^Came across the exact diff when i was building trikes, they are for ride on lawnmowers apparently, they
KiM
Let me know if you can track it down,
Users browsing this forum: Heterodyne and 12 guests
