Ypedal wrote:a low and slow self discharge cell happens, it can still work.. but you need to figure out if it will take energy or not. ie : permanent loss in capacity vs slow discharge you can deal with using a single cell charger.
yes, using the ballance leads is fine.. no more than 2 amps tho.
dnmun wrote:.... because of a miscalibration of the resistor divider bridge to the comparator on that channel.
no reason not to open it to work on it. i don't think paul really warrants things once you use them and if the BMS channel is miscalibrated, then i suspect he would wanna know that.
so you really have to actually charge that cell up to at least 3.65V while the others are fully charged and run it through several discharge cycles to see where the cell balances again. that's why it helps to measure the individual cell voltages while charging. to see where they balance. you do not know if it is a runt or if it is just not getting fully charged.
liveforphysics wrote:You need to charge and watch the low cell's voltage relative to the others while charging. If it's first to fall off the cliff and first to reach peak voltage, it's a weak cell group, likely just had a paralleling tab-weld disconnect (and no, this won't change it's voltage, just capacity of that cell group).
Ypedal wrote:liveforphysics wrote:You need to charge and watch the low cell's voltage relative to the others while charging. If it's first to fall off the cliff and first to reach peak voltage, it's a weak cell group, likely just had a paralleling tab-weld disconnect (and no, this won't change it's voltage, just capacity of that cell group).
it's a single 20ah pouch cell.. not 26650's..
liveforphysics
I am betting he is mistaken. I thought all the cell man packs with a BMS were tab welded 26650's. Unless very very early on you got one of his first couple packs using pouches.[/quote]
[quote="John in CR wrote:This pack is new enough that Cellman should cover it. Was it the same cell that was at 3.48V the cycle before, and then wouldn't charge above 3.33V .John
John in CR wrote:If the cell will take near 20ah charge from it's current status, then there's something wrong with that channel of the BMS. If not then that cell is a problem, and needs replacement. If the cell is stable, just lower capacity, and if you're on your own with it (hopefully not the case), then the fix might be as easy as paralleling just one or more 26650 A123 cells with that weak cell to make up the difference...not pretty or elegant, but a fix. I've got a number of those cells at various capacity, so we could get you up and running in a jiffy.
John
Lenk42602 wrote:So Luke, I need a little help understanding "cell group" - my understanding of the pack's operation is that the BMS controls and monitors charge on each cell via the balance wires. Based on what you have indicated, it sounds like the BMS monitors cells individually and in "groups"?
Users browsing this forum: Hero_004 and 11 guests
