toolman2 wrote:have you got the right setting for 120/60 deg halls? you can sometimes have a wrong hall/phase combo that is kinda ridable and ive been fooled for a bit.
it would be good to try all the hall combos, even though the colours match, following john in cr's officially correct hall instructions![]()
but failing that try another controller, you can have a partly blown phase, i had some high side fets blows on a kelly and it ran poorly giving fault codes.
also i notice you get the old "regen that you didnt ask for" trick from the kelly when you lift off and re-apply throttle, -really annoying kelly habit that one.
i try all combination of colour, and this is correct i'm sure, what you want to say with:"also i notice you get the old " old KHB version?
Exist new KHB version? Yes i notice when you open att full throttle and after you make partial throttle, controller try to slow down the wheel with apply little regen, but for kelly this is normal operation...
I want only understand why this controller make this bad sound and make less power than KBL
Is impossible i have 3 Khb broken, but is possible if i have a series with problem, from xxx serial to xxx serial...
But i can only suppose
