BMSBattery 12 Fet KU123 Controller Voltage
Postby potatorage » Fri May 04, 2012 10:01 pm
Hi, I purchased a BMSBattery 36V 500W controller last year and I was wondering what the maximum voltage I could run was. I believe there are 63V caps inside, but since I opted for the 36V version, would 16S LiFePO4 48V work with the controller without modification? Thanks!
potatorage
Re: BMSBattery 12 Fet KU123 Controller Voltage
Postby chvidgov.bc.ca » Fri May 04, 2012 11:45 pm
Yes. I regularly run the KU123 on multiple bikes with fully charged 16S 48V Ping batteries which are around 60V fully charged. No issues so far. Unless there are two versions of the controller? I think they are identical versions, perhaps a different LVC that's all.
CatrikeRoad Rear9C 2805 KU123Sensorless CA
DevinciVancouver Front9C Disk
Rebike 20"R/16"F Bent C404 Front 48V 20A Crystalyte Pedal First
CCM 26" Cruiser Nexus 7 C406Front 48V 35Amp Crystalyte Start Imm
Sun EZSport CX 26R/20F LWBent C405 Front 48V 35Amp Crystalyte Start Imm
Giant Revive DX 20" Nexus 7 RearSusp with 9C Front 48V KU123
Actionbent T1 trike with Rear9C2806 KU123Sensorless CA
Vision R40 Recum USS SWB EZEE
CannondaleHooligan Cute100 48VHead 60T ring KU63
chvidgov.bc.ca
Postby Dear-user » Wed Aug 01, 2012 2:24 pm
I confirm that it's possible to go at least to 50 volts with this controller, as I do.
But I'm curios if it is possible to go further? Replace these two 63V caps and voila! Next limit I'm aware of is 80V mosfets.
Dear-user
10 µW
10 µW
Postby dnmun » Wed Aug 01, 2012 2:57 pm
yes, 48V lifepo4 is actually best when used with a 36V controller. a 48V controller has a 40.5V LVC and a 16S lifepo4 pack would only be down to about 2.5V/cell at that point under load when the controller cuts out. so 36V is better than ok.
dnmun
Postby spuzzete » Thu Aug 02, 2012 2:22 pm
Interesting information!
I have a ku123 controller 500w 36 volt from bmsbattery too. I am using a 10s Li-ion battery (41-42v fully charged) and I had no problems so far.
I was wondering if I can use a 15s Li-Ion battery pack (61.5v if cells charged @ 4.1v / 63.0v if cells charged at 4.2v) without changing the capacitors in the controller. Is it too risky?
8)
My little experimentation cave ( e-bike / li-ion batteries / electronics / etc. ): jacopo.tk
My Build: 36v 24ah "Home Made" Li-Ion & 500W rear Bafang
spuzzete
Postby dnmun » Thu Aug 02, 2012 2:58 pm
nope, imo the 63V is the spec, and you have to read all the legalese that goes with it but they can do more by a small margin imo. i have had my 9C infineon controller pegged at 90V stock and it did not blow up the controller 63V caps but that was for a few seconds under no load power, about a minute exposed at that voltage.
i would not last long imo if i continued, but i don't think you will have problems because of voltage breakdown with your pack. limno4 is it?
dnmun
Postby spuzzete » Thu Aug 02, 2012 3:09 pm
Thanks for the info dnmun.
My battery pack is actually Li-Co made with 18650 laptop cells. In the future I will probably use Li-Mn.
The voltage drops 2-4 volts on my 10s pack (from a fresh charge) applying full throttle and then voltage climbs back up. The pack is 24Ah nominal.
I have a spare KU123 controller, so I guess I will give it a try.
8)
spuzzete
Postby Dear-user » Wed Aug 08, 2012 4:49 pm
I belive caps should not be overvoltaged. They could withstand some short overvoltage, true, but they degrade for sure. Afaik it's not a good idea to run it that way for a long time.
Besides it's quite easy to replace them for 100V or 160V caps.
Dear-user
10 µW
10 µW
Postby spuzzete » Wed Aug 22, 2012 11:22 pm
So I completed a 15s Li-Mn (Makita cells) today and I tried on the bike. The pack voltage was 61v at the beginning of the ride. No problem with the controller, the bike is really fast compared to my 10s li-ion battery pack. The acceleration is much better and I hit 45kph pretty quickly. After a couple of kms the max speed was about 42-43kph.
8)
spuzzete
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 10 guests
