How often do you bleed your brakes?
Postby crusoe » Tue May 15, 2012 10:18 pm
Hey guys, just wondering how often everyone bleeds their hydraulic brakes? I've got a pair of Hayes HFX 9's and I've ridden maybe 80-90km and they already need another bleed. I was riding today, and by the end of the 18km ride I could pull the levers all the way to the handle bars :? I have already had to completely rebuild one lever's internals (as soon as I bought the bike, before any use. Seller lowered price :) )
It should be noted that I don't see any fluid leaking anywhere from the brakes...at all. None on the discs, none on the bolts connecting the lines to the calipers, none from the overflow holes on the levers.
I'm thinking it's just from the hard braking that I do? I usually cruise around 50-60km/h all the time, some street, lots of trail riding with largely differing grades. Any input from the community would be great!
crusoe
Re: How often do you bleed your brakes?
Postby DAND214 » Tue May 15, 2012 10:58 pm
Two years later and still no need to bleed them. Shanimo deore with 203 rotors frt and raer.
They are great for normal riding matbe not constant blasting from turn to turn on a race track. But are great on the road and trail.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby Kirk » Thu May 17, 2012 5:39 pm
I've never had to bleed the brakes on any of my four trikes. They are all equipped with SRAM Avid BB-7s. I change the pads once a year because they are cheap.
Stable:
05 Catrike Road (Yellow), 20" 48V 1000W GM hub motor,12s24Ah Lipo batt.
12 Catrike Expedition (Candy Purple), 18s32Ah Lipo batt. Lyen 18 FET low RDS controller, C'Lyte HS3540 hub motor, CA-SA, Mueller Bros. Windwrap XT fairing, Terra Cycle Cargo Monster extension. Still evolving, should be interesting by next Spring.
2011 Roll Over America tour, 50 Velomobiles, 5000 Km, 24 days, Portland, OR-Washington DC, July 28th-August 24th 2011, damn I was tired after that.
Kirk
Postby Ricky_nz » Thu May 17, 2012 7:38 pm
I have never blead my Hayes HFX9s 3Years+
Avid Elixer R hasen't been blead since installed on the bike >1year ago.
I would only bleed them if there is an obvious problem.
The poster above would need a hydraulic press to blead his mechanical brakes :lol:
Latest Projects: High power vector controller for Turnigy 80-100, Keewe Stealth DJ bike with Turnigy 80-100 180.
Youtube channel: http://www.youtube.com/user/rwhitenz?feature=mhum
1) Specialized Hard Rock + surviving 1/2 of Elation 300W + Sick Bike Parts freewheel and sprockets + echo cranks.
2) Commuter bike with 1000W GM rear hub.
Ricky_nz
Postby crusoe » Fri May 18, 2012 9:19 am
So I've found the culprit! The fluid transfer port, where the two halves of the caliper make contact (metal on metal), had many small knicks in the metal, somehow. Even after brand new orings, I still had the problem.
1. Hack solution, used an elastic band "gasket" as a temporary fix and it's held up so far
2. called up our local gasket supplier and they're going to karma me a piece of 1x1ft piece of scrap, oil resistant, 1/32" thickness gasket sheet, so i can cut out my own gasket. I"ll be sure to update the thread after a few weeks of riding to let others know if it's a good long term fix.
Hopefully I won't have to drop $200 on a set of new brakes!
crusoe
Postby ZOMGVTEK » Fri May 18, 2012 9:51 am
On my $60 6 piston Gatorbrake set, I 'bled' it once, after shortening the hose. My method of bleeding them involved quickly smashing the lever for 30 seconds. It takes extremely little travel to lock up the front, its quite firm, and its never really changed after a year or so.
It really looks like the smaller brakes take much more effort to bleed, since my brake was dumb easy to bleed with literally 0 tools in seconds. I could see tiny bubbles come out of the fluid in the reservoir, and I stopped when they went away.
ZOMGVTEK
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 4 guests
