Doc's Watercooled Hub motor project ( 5403)
Postby Doctorbass » Sun May 20, 2012 12:32 am
8) :D :mrgreen: :D 8)
UPDATE ON PAGE 3 ( new principle and more efficient and simple) http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=39933&start=30
Yes... This motor still have not make a single rotation on any of my ebike, but it will be liquidcooled !
I want it to me a REAL beast and to have it able to sustain that title of real beast during an entire run !!!
No more motor overheat problem.. no temp gauge to watch and that require reducing the throttle!
I already remachined the axel to have 3 x 10 gauges wire to fit perfectly and the other side of the axel a similar groove but that will contain the 2 brass pipe for the inlet and outlet!
To do that i needed to replace the smaller 6004 bearing of the axel by another 6005 to accomodathe enough room to have the two pipe required room.
The big probelm was to have enough I.D. to have enough liquid flow to make efficient the cooling, but the room for the pipe is restricted. I finally found a great way to have really thin tube thickness and not too gfragile. I found that using TV telescopic antenna brass tube is just perfect !!
So the I.D. is like 1/4 inch !! and the O.D is like 9/32" !!
I dont have the time and $$$ to have custom machined aluminum path for the liquid so i dediced to go with copper tube
Problem with copper tube is that the effective surface that can be in contact with the aluminum of the stator is really low .. unless the tube are square.. but i have normal tube :lol: .. and they are round !
So the way i found is to add some 22mil copper sheet that increase the effective surface in thermal contact with the aluminum of the stator and to solder them to the spiral copper tubes.
No worrie i will post pictures of the project soon. :wink: I expect to have 4 foots lengh of the 1/4" I.D. copper tube touching the copper sheet that are in contact with like 70% of the aluminum of the stator.
Worst case of use of that liquid cooling setup might be to extract like 4-5kW of heat for a 16-17kW power input... at 130-140km/h
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Re: Doc's Liquid cooled 5403 project
Postby Doctorbass » Sun May 20, 2012 12:43 am
Some first pics:
:wink:
I wil add some aerospace grade NUSIL thermally conductive Adhesive between the aluminum and the copper as well.
Also it's not shown on the pictures yet but i will also cover the center 6 branches star aluminum with copper sheet that will have a spiral of copper tube soldered on it. ( see the image on the paper sheet ( wich represent the center copper sheet that will be placed on both side of the motor
I might call it PORJECT SPIDER :twisted: ( the desing look like a cobweb :lol: )
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby hjns » Sun May 20, 2012 12:52 am
Just an idea, if you fill the motor with a little bit of ATF oil, it will much better transfer the heat from the coils to your superduper copper pipe filled with supercool liquid. Alternatively, why don't you circulate oil in the whole motor, and use the copper pipe as radiator in front of your bike?
Anyway, I love what you do, so keep it up!
Henk
High speed commuter w/ modified Lyen 18 FET 4110, 12AWG traces, extra Caps, beefed up shunt, modified Cromotor w/ thermistor, 10AWG phase wires. CAv3B22 with power-throttle limited to 8kW and 130oC motor winding temp, w/ GPS-enabled CA analogger. 20S 13.5Ah Lipo Zippy pack. Fusion FS frame, Fox RL rear shock, Fox F100 front fork, Schwalbe Fat Bob tires, HALO SAS 26inch rims with custom 12G(r) and 14G(f) black Sepim spokes from JRH and laced myself.
Commuter Cromotor build
hjns
Postby Doctorbass » Sun May 20, 2012 12:59 am
hjns wrote:Just an idea, if you fill the motor with a little bit of ATF oil, it will much better transfer the heat from the coils to your superduper copper pipe filled with supercool liquid. Alternatively, why don't you circulate oil in the whole motor, and use the copper pipe as radiator in front of your bike?
I see your suggesting, but I dont want any oil dripping probelm over the time....
Also.. my side cover are perforated with multiple holes already.. :lol: to contribute to cool it down
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Bison_69 » Sun May 20, 2012 12:09 pm
Hi Doc,
Let me know if you need any scale CAD drawings (2 or 3D) for your project....
Ok Bye...
=>First eBike conversion in progress!...
=>Giant DH Comp 2004 (with damageless torque arms)
=>Crystalyte rear HT hub-motor
=>Lyen 12 x 4110 MOSFET Extreme Modder Controller (from 24 to 100V)
=>Large screen CycleAnalyst
=>Batteries are yet to come --(may be Headway 40152S 15Ah in 20S2P setup)
=>SolidWorks Design - electric Trike for a Montreal friend well known on the forum...Maxwell65
=>"Your tiny little human brains. How do you get around in those things?"
Bison_69
Postby wojtek » Sun May 20, 2012 3:32 pm
looking forward to the first video in action :)
subscribed*
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby Doctorbass » Sun May 20, 2012 5:31 pm
Bison_69 wrote:Hi Doc,
Ok Bye...
Thanks ! i keep that in mind!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby nechaus » Sun May 20, 2012 7:12 pm
Just a Suggestion.
What about using sometype of thermal paste (micronised silver) in their or heat transfer material.. not just bare copper ? stuff we use in pc's..
Be awesome to get them pipes icy cold
Magic pie Dual Suspension
Peak 6kw Air cooled
Kelly controller (mini kbs series, smaller than a coke can, can do 80+ battery amps peak, Favorite small controller. Really punchy)
20s 16ah
60 kmh,
Safe, Beautiful handling.
nechaus
Postby rojitor » Mon May 21, 2012 7:19 am
This is very interesting. Subscribed.
rojitor
Postby rojitor » Mon May 21, 2012 7:20 am
Btw i have got a 5403 too, will you use single freewheel doc?
rojitor
Postby Doctorbass » Mon May 21, 2012 8:58 am
rojitor wrote:Btw i have got a 5403 too, will you use single freewheel doc?
Yes, but i'll have enough space for a freewheel with the 11 tooth if i need :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Mon May 21, 2012 9:01 am
auraslip wrote:Doc, did you see keyne's liquid cooled motor? https://sites.google.com/site/shelbyele ... -dirt-bike
Yes i saw it, The X5 stator have no corner where to put these 45 degree sheet of material like these cromotor or 9C or HX motors. That's why i wanna use copper tubing with copper sheet surface enhencement.
But yes keyne's cooling idea was nice too
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Mon May 21, 2012 9:13 am
Some update on the heat collector parts for the tubing fabrications:
( i'll use a 20T press to flaten a little bit center the spiral to improove the thermal contact, but just enough to not reduce the I.D. too much.)
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Trackman417 » Mon May 21, 2012 10:14 am
You just aren't happy with anything stock are you? :!:
Subscribed! :mrgreen:
K2 Sidewinder
H4065 36 mph
20s2p 10aH lipo battery pack
If it didn't kill you, it just built your character.
You know your bike is powerful when even you, the builder, can't control it.
Customer 00001 at our very own Bigmooses online store http://mtg-technologies.com/zencart/ Great guy, great products.
Trackman417
Postby Doctorbass » Wed May 23, 2012 10:00 pm
Trackman417 wrote:You just aren't happy with anything stock are you? :!:
Yes.. everything must be mod according to our own requirement :twisted:
Today i just finished to assemble all that copper together and soldered everything with some 50/50 lead.
I know it appear a little bit heavy but this is the compromise i found for guarantying that there is no possible leak.. so i choosed to keep the concept of copper tube combined with fins that suck the heat from the stator structure and bring it to the copper tube with the lead junction.
I will also put a high performance thermally conductive adhesive silicon that will fill the area between the copper fins ( blades) and the stator structure. so there will be no insulating air gap .. just some thermal conductive stuff :wink:
As well, all the radial copper blades will be bended to be as close as possible to the stator 6 branches.
This is the first half( side) of the copper system. I will begin the second half this weekend
If you have any suggestion to improove that existing concept, please let me know!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby deVries » Wed May 23, 2012 10:05 pm
:twisted: :shock: :lol:
deVries
Postby nechaus » Thu May 24, 2012 1:28 am
I think you have one of the most copper filled motors out there lol
Peak 6kw Air cooled
20s 16ah
60 kmh,
nechaus
Postby keyne » Thu May 24, 2012 5:17 pm
I'm really interested to see how your project goes. It is very similar to my first attempt (undocumented) at cooling a hubmotor - I decided it was too hard, too much work and would add too much weight in the end. How are you planing to get the coolant in and out of the motor? Are you going to do two sides or just the one? Good luck - looks good so far :D
keyne
Postby keyne » Thu May 24, 2012 5:40 pm
One thing you might want to add to your design is to put thermally conductive epoxy all over the windings to try to improve the thermal path from the windings to the stator. The air gaps in the windings and the winding paper is the major barrier. I found with mine that there was a large delta T (up to 40degC) which was improved substantially by adding about 60g of themal epoxy to the sides of the windings.
keyne
Postby Cowardlyduck » Thu May 24, 2012 6:08 pm
Hey, I'm not sure if it's possible to do, but it would be cool to see how much power it takes or saves in doing this.
I.e. It would be cool to see, how much power it takes to maintain, say 80kmh, on the flat before you add the water cooling, and then, how much more (or less, due to better efficiency) after you add the water cooling since the power for pumps, fans etc will coming of your pack still.
Cheers
Cowardlyduck
Postby Doctorbass » Fri May 25, 2012 2:17 am
I am using the two side of the axel one side have the phases, hall and temp sensor wires and the other side have the two 1/4 tubes (IN and OUT).
I modified the axel and the side cover to accept two 6005 bearing instead of one 6005 and one 6004. The side with the replaced 6004 for a 6005 have the two tubes. I will post pictures of that soon.
I am 100% sure that the power required by the pump ( 24W) will be largely compensated by the efficiency gain in power!!! at high temp the hub motor are like half their normal power...
This will improobe the max power duration for each ride ... or the average power level as well.
I ordered these:
Swiftech MCP655
Swiftech MCR-320 Quiet Power Series Radiator
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Fri May 25, 2012 2:18 am
keyne wrote:One thing you might want to add to your design is to put thermally conductive epoxy all over the windings to try to improve the thermal path from the windings to the stator. The air gaps in the windings and the winding paper is the major barrier. I found with mine that there was a large delta T (up to 40degC) which was improved substantially by adding about 60g of themal epoxy to the sides of the windings.
That is a nice idea.. maybe trying with my special aerospace thermally conductive adhesive RTV :wink:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby keyne » Fri May 25, 2012 2:59 am
I'm curious to know where you are going to mount the pump and radiator?
I found with my system the limiting factor was not the pump or the radiator but getting heat to transfer from the windings to the stator more efficiently. A larger pump or larger radiator doesn't help much there. You'll find it makes a huge difference compared to an air cooled motor - I don't have to worry about overheating my motor anymore. Also are you going to use a fan on your radiator (eg. for when you have stopped after a long climb)
keyne
Postby Bison_69 » Fri May 25, 2012 7:53 am
Hi Doc,
Be carefull with this company... there are complain from customers on their website which says that they are not respecting their waranty...
http://www.swiftech.com/warranty.aspx
SwifTech Disclosure catch
(57.28 KiB) Downloaded 4 times
I think you would be better off buying a motorcycle or automotive electric water pump from a small car serie like the one found in a Toyota Yaris or any other make. (which you could buy locally as well)
Bye...
Bison_69
Next
Return to E-Bike Technical
Who is online
Users browsing this forum: IRON DOG and 12 guests
