cellman battery help hooking up to controller.
Postby Mudduck » Thu May 24, 2012 6:17 pm
Hey guys I just got my new 7t mac and as you all know they dont come with instructions.I emailed paul but I thought i'd ask you guys.My battery has 3 wires coming out of it and my new controller has 2.I didnt have any anderson contector so I just ordered some,had to do it sooner or later.let me know what you guys think.Thanks
battery 002.JPG (68.72 KiB) Viewed 330 times
Mudduck
Re: cellman battery help hooking up to controller.
Postby cal3thousand » Thu May 24, 2012 7:00 pm
I'm interested as well. Hoping to get a 7T from cellman soon. How long did it take you to get it? He must be busy, because it's a few days in between contact with him.
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby Mudduck » Thu May 24, 2012 7:07 pm
About 4 weeks from getting a hold of paul to shipping..I shipped sal..new tracking system worked really well.didnt have it my first order..
Mudduck
Postby cal3thousand » Thu May 24, 2012 7:11 pm
What battery is this? Have you tested the white wire for resistance or voltage to ground?
cal3thousand
Postby Mudduck » Thu May 24, 2012 7:18 pm
Haven't done any thing yet I don't have the connectors yet so just asking around for now..it hooked up easy with my old not really mxus geared kit.12p3s 39v 6.9 ahr..a123.i was you live in cal you should have a order faster than me,orders come into cal.
Mudduck
Postby cal3thousand » Thu May 24, 2012 7:29 pm
Hmmm... well I don't know what that white connector would be, but if you have a Multimeter, you could find out more and decide whether or not you need the connection.
I think it should work if you were to rearrange the locations so you can just plug black to black and red to red (assuming those are following the standard +/- )
cal3thousand
Postby Mudduck » Thu May 24, 2012 7:33 pm
Check out the way the red plug faces..really weird.this was the first time I ever saw Anderson's.
Mudduck
Postby cal3thousand » Thu May 24, 2012 7:36 pm
Mudduck wrote:Check out the way the red plug faces..really weird.this was the first time I ever saw Anderson's.
Oh..... :shock:
Didn't notice that before. Where did you get this battery?
cal3thousand
Postby Mudduck » Thu May 24, 2012 7:43 pm
From Paul,I ordered a battery and a mxus kit..sold the mxus kit and ordered the Mac.. Battery works great.
Mudduck
Postby ebikesrfun » Fri May 25, 2012 9:40 am
I have a Cell Man battery as well. The white connector is the precharge. You connect the black and white connectors first which charges the capacitors in the controller before plugging in the red connector. The white connector is wired inline with a 200 ohm resistor.
ebikesrfun
100 µW
100 µW
Postby Mudduck » Fri May 25, 2012 11:07 am
Thanks for the reply..I hook the white wire up to the positive wire.theres only 2 wires on my new controller..
Mudduck
Postby ebikesrfun » Fri May 25, 2012 4:47 pm
Cell Man should have given you a matching pigtail that you splice with your controller. The pigtail has bare wire on one side for positive and negative and has three matching Anderson connectors on the other side. The resistor is located on this pigtail.
ebikesrfun
100 µW
100 µW
Postby 999zip999 » Fri May 25, 2012 4:50 pm
Yes to charge the controller so no spark when you hook up the main red wire. You don't have to leave it hook up but is hot 40 plus volts. Just precharge.
999zip999
Postby Mudduck » Fri May 25, 2012 8:16 pm
Here is a picture of what paul sent me..and the plug for the controller..
pigtail 001.JPG (66.89 KiB) Viewed 259 times
pigtail 002.JPG (90.41 KiB) Viewed 259 times
Mudduck
Postby ebikesrfun » Fri May 25, 2012 11:28 pm
Seems like you're missing the pigtail with the three Anderson connectors and precharge resistor. Paul should be able to send you one.
ebikesrfun
100 µW
100 µW
Postby granolaboy » Fri May 25, 2012 11:57 pm
That's pretty cool that he includes the precharge resistor setup...one more reason to go with cellman
gio 500+ 60v shunted
gio 500 60v shunted
2009 motorino xph
granolaboy
Postby Mudduck » Sun May 27, 2012 10:41 am
Thanks everyone paul got back to me,got it all figured out.paul sent me a picture how to hook up..Thanks all.
Mudduck
Postby Tommy L » Sun May 27, 2012 5:06 pm
Mudduck wrote:Thanks everyone paul got back to me,got it all figured out.paul sent me a picture of want I didn't to hook up..Thanks all.
Could you please post the picture so we can see too.
Thank you!
Tommy L sends.... \\m//
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Postby Mudduck » Tue May 29, 2012 7:37 am
Here a picture of what paul sent me (I had to take a picture of it and post it this way,for the life of me I couldn't attach the emailed picture).
battery layout 007.JPG (86.53 KiB) Viewed 138 times
Mudduck
Return to E-Bike Technical
Who is online
Users browsing this forum: dnmun, methods and 12 guests
