I ordered and received the following http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=130696276204&ssPageName=ADME:X:eRTM:US:1123#ht_7313wt_948
The only thing different from the listing above is that I had them mount the motor in a 20" wheel for me, cause I am putting this on a folding bike with 20" wheels.
I put on my bike with my 48v battery, connected all the wires, and then the problems arose.
When I turn the key, the headlights and horn work, but the wheel does not spin.
I started unhooking and re hooking up wires, when I plugged the throttle wire back in, the wheel spins at full speed. I have no control with the throttle whatsoever, it just spins at full speed.
If I leave it connected and turn the key on and off, it does not start spinning again until I unplug and replug the throttle wire.
I am not sure what else I can do, is it possible that the throttle is broken, or is this more of a problem with the controller?
I do have another throttle from another kit, but I don't know what wires do what, as the colors are not the same. I will attach some pictures if I can figure out how.
