ZOMGVTEK wrote:Generally the motor will have 6 windings that are twisted into 3 pairs. Break these pairs apart and run 6 phase wires out of the motor. Then you can do some snazzy switching for series/parallel.
Does the cromotor have an angled stator?
John in CR wrote:There's a big thread about series/parallel and Delta/WYE. I'm not sure anyone has come up with something reliable at high power. DocBass tried it with big expensive contactors and ran into the problem of the spring loaded contactors losing contact in bumpy conditions.
zombiess wrote:John in CR wrote:There's a big thread about series/parallel and Delta/WYE. I'm not sure anyone has come up with something reliable at high power. DocBass tried it with big expensive contactors and ran into the problem of the spring loaded contactors losing contact in bumpy conditions.
I would use large paralled fets to act as the switches.
zombiess wrote:I have a Cromotor Hubzilla that is setup for 17-18KV, it's only a 2 turn motor. I'm told I can modify the wiring and run it in series. If I wanted to do this how would I go about wiring this motor so it's setup in series and not such a heavy load on the controller. I'm thinking setting up a switching setup so I can go between series parallel if possible.
zombiess wrote:I would use large paralled fets to act as the switches.
rkosiorek wrote:zombiess wrote:I would use large paralled fets to act as the switches.
only complication is that the fets switch must be able to switch AC currents. standard fet relays and switches are dc only.
rick
Users browsing this forum: aroundqube, Beagle123, hochdorf, Nanoha, zypher and 9 guests
