Mac Motor Freewheel Options
Postby Degull » Wed Jul 25, 2012 7:55 am
Hi everyone. Was hoping to get some feedback on what types and sizes of freewheel fit on the Mac motors. I tried and a Sun Race 9spd freewheel last night and there was not enough room on the drive side. I could use some spacers and dish the wheel but I was hoping that where some other options. 7 speed is good but it really limits the choice of shifters. Any suggestions?
Degull
Re: Mac Motor Freewheel Options
Postby motomech » Wed Jul 25, 2012 3:03 pm
It's a short list of one.
You will need the smallest cog to be as small as possible, which is an 11T
Only DNP Freewheels offer this.
The most speeds that will fit a 135 mm drop-out with that motor is a 7-speed..
DNP 7-speed, period.
Motomech(reformed I.C.E. enthusiast)
2003 Rocky Mountain Edge w/2WD. , Dual Ananda Q100 "fast wind" W/stk. controllers modd'ed to 17A, 28 mph on 12S Lipo, Stand Alone CA, Cycle Lumenator
2007 GT Idrive 5 3.0, MXUS geared mini/Lyen Mini-Monster on the frt.
viewtopic.php?f=4&t=40567&p=592630#p592630
viewtopic.php?f=6&t=235&p=651777#p651777
motomech
Postby cal3thousand » Wed Jul 25, 2012 6:53 pm
Unfortunately the best option is the DNP 11T-34T or 11T-32T freewheels.
Methtek.com has some.
#1: Diamondback Menona 700c (Commuter)
M/C: e-BikeKit geared rear w/BB7 with 12FET 40A Infineon ebikes.ca
GM 48V LiFePO4 10Ah racked; moving to 12S Turnigy 10Ah framed
+ Speedict, XC30TK disc, Alex Adventurer 700c Disc, Tektro 180mm hyd. with 42mm Kenda Urban
#2: Norco VPS Six DH (Fun) WIP
M/C: Clyte HT3525 (Thanks Meth!!!) http://Methtek.com with Lyen 18FET 24S Regen
Battery: 24S Turnigy 10Ah frame (ABS)
#3: Wifey Bike, Giant eSuede fully customized WIP
cal3thousand
Postby neptronix » Wed Jul 25, 2012 6:54 pm
7 speed dnp works great.
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby DAND214 » Wed Jul 25, 2012 10:46 pm
Only a small spacer and a DNP 8 speed works. Oh if the swingarm is alloy use the 7 speed, don't try to stretch aluminum!
Not bad with 9 speed shifter and 8 derauler. Shifts good but has one missing.
I know many say you don't need but the 11t since it's powered. I like to be able to pedal at differant speeds other than WOT. So using 8 or 16 of the 24 works great for other than full throttle.
Dan
It sure would be nice to know where we are all located, ON THIS WORLD.
Fill in your profile. It doesn't hurt.
I know some worry about being found.
I wish someone would find me.
DAND214
Postby Degull » Sat Jul 28, 2012 9:06 am
7 speed it is! I agree that 11t would be the way to go. I still like to pedal my bike and there will many times when I leave the battery at home. Thanks.
Degull
Postby Warren » Sat Jul 28, 2012 1:12 pm
Both Shimano trigger shift pods, and SRAM twist grips are available to bike shops, from J&B. Any bike shop can order from J&B, if they don't already have them in stock. These will work with any Shimano rear derailleur, through current 9 speed, and Shimano compatible SRAM rear derailleurs. The 7 speed shifters available now are not the top quality ones available when 7 speeds was new, but they work just fine. The important part is to used plastic lined, derailleur specific, cable housing, and a good quality rear derailleur, not steel and plastic crap, like I see on many e-bikes. If you are actually planning to ride this like a bicycle get a real derailleur!
http://www.jbimporters.com/web/checking ... mber=53745
http://www.jbimporters.com/web/checking ... mber=53488
Warren
Postby Degull » Sat Jul 28, 2012 9:06 pm
Warren wrote:Both Shimano trigger shift pods, and SRAM twist grips are available to bike shops, from J&B. Any bike shop can order from J&B, if they don't already have them in stock. These will work with any Shimano rear derailleur, through current 9 speed, and Shimano compatible SRAM rear derailleurs. The 7 speed shifters available now are not the top quality ones available when 7 speeds was new, but they work just fine. The important part is to used plastic lined, derailleur specific, cable housing, and a good quality rear derailleur, not steel and plastic crap, like I see on many e-bikes. If you are actually planning to ride this like a bicycle get a real derailleur!
I'm on the hunt for some old school mountain bike thumb shifters at the moment. My rear derailleur is an older shimano XTR. I agree with you. I don't mind riding a 7 spd as long as the gears work flawless. Installing good gear cable and a quality rear derailleur will make up for the gear count.
I can't use the rapidfire type shifters because of the switches on my throttle. It has a cruise and three speed switch that get in the way. Over the bar thumb shifters make life much easier.
Degull
Postby Warren » Mon Jul 30, 2012 11:03 am
Warren
Return to E-Bike Technical
Who is online
Users browsing this forum: Google [Bot] and 6 guests
