Sacman wrote:Also, you can remove 1mm or 2mm of material from your bike frame's disc caliper mounts or the caliper's mounting brackets (either or both), in order to increase distance between your disc and the side covers to your hubmotor. Local bike shops do this all the time and even have the special tool to remove the material exactly perpendicular to the mounting holes. You can bring your bike to them and have it done if you're not comfortable doing it yourself.
jateureka wrote:Is there much difference in stopping power between the Radius and Avid BB7?
d8veh wrote:With many motors you can solve the problem with a larger disk, which usually brings the caliper further away from the motor. Normally 180mm is enough. You only need a new disk and a new caliper mount.
Sacman wrote:Justin at ebikes.ca sells an Ahlonga low profile mechanical disc brake caliper for $30. It's supposed to be thin enough to fit fine between the front forks and a 9C hubmotor. Look in the Store - Parts - Brakes section.
Users browsing this forum: Bing [Bot], petemarconi, psbot [Picsearch] and 19 guests
