by Drunkskunk » Mon Jul 30, 2012 12:32 pm
regardless, I would run away from those controllers.
First, the 4410 FET is fine, sort of. But there are better choices in FET. It can handle less than half the power of a 4110 FET, so a 24 FET controller with 4410 FETs is half as good as a 12 FET with 4110 FETs.
More FETS won't make you faster. The FET is just a switch. It turns on, you get power. A Single 4110 FET can handle 180 amps at 25c(77 degrees f) 130 amps at 100C (212 degrees f). So in theory a 6 FET controller is overkill for most extream Ebikes.... If you could keep the FETs cool enough.
One reason for more FETs is heat disapation. The more current handled by a FET, the more it heats up. If you double the number of FETs, you cut the amount of currnet in half in each one, meaning half the heat each one needs to get rid of.
Ultimatly, it just depends on the motor you have and the current you're going to run as to what's best.
