Shenzhen (ecrazyman) Controller Information
Re: Shenzhen (ecrazyman) Controller Information
Postby Mike1 » Mon Feb 23, 2009 2:44 pm
If the throttle signal wire is giving the correct voltage (mine goes from 1v to about 3.8V) then I would guess that the phase wires are in the wrong order.
Here's the permutations I use.
Hall
Sensor
Wires
BGY BYG
Motor Wires
BGY BYG GYB GBY YBG YGB
Theoretically there are 36 permutations but the 12 above cover them all. All the others are just rotations of these.
I was lucky with mine, the colours matched what was already on the bike.
Mike1
Postby diver » Mon Feb 23, 2009 3:42 pm
I think its just dead, lol. I think i will just buy another one from knuckles. Ive played with all possible combinations, tried a different throttle. We bought two at the time and the other one is over at my buddies house as we have not tried that one yet. I think i will see if i can get that one and wire it up . Hopefully it is alright
thanks
diver
Postby Mike1 » Mon Feb 23, 2009 3:50 pm
I hope mine lasts a little longer than that :)
Waiting for more batteries to arrive so I can re-program the LVC and go to 72V. :D
Mike1
Postby ColdCoffee » Wed Mar 16, 2011 10:11 am
Hi there!
Don't know if anyone can help me here or whether it's the right thread to post (plz move if not).
Bought a 1000W 48V Goldenmotor back in 2010.
It's the fat model with the 3 silver rings like this, but 28" spoke wheel, front.
Can anyone identify the controller and help me to lower the low voltage cutoff. Which resistors to modify?
It somehow looked so similar to the pics here (same case, wires, capacitor placement) but still is different.
It would already help if someone would have a pic of another version, e.g. 36V, for comparing differences.
I've been using it for months @ 72V. Know I shouldn't do that (or at least replace capacitors) but it works fine and provides the last missing small speed gain.
My bike gets ~45km/h @ 48V normal road and load vs. ~55km/h @ 72V ... as city speed limit is 50km/h here and cars always drive 50-60, it's much safer @ 55km/h, the cars (or better car masses) don't overtake you permanently and you've also less trouble with classic mopeds :-)
At 48V extra pedaling was much too hard to gain at least 50km/h.
I use 6 12V 12Ah lead batteries and I already intergrated a complete strong serial/parallel switch system down to 12V for charging with standard car chargers.
It would be easy to switch to 36V 24Ah or even 24V 36Ah without modifications. This would be really nice for travelling longer distances in spite of lower speed.
But unfortunately below 48V nothing works. But using 48V with 6 cells requires permanet switching to discharge the cells symmetrically. 36V would be much less annoying and also still more gain in range. Don't know if 24V is possible but wouldn't focus on that, since my other extra electronics (complete LED light system incl. indicator+brakes, lock system, etc.) just work 36V-72V at the moment, too.
Any other possibility would be upgrade to 96V and switch between 96V and 48V. But I wouldn't expect the controller to handle THAT. And since 48V->72V weigth is already at absolute limit one man can lift up/down cellar stairs, another 8kg simply not possible as I couldn't handle THAT ;-)
I would appreciate any help to lower the LVC. Can provide more pics/information if necessary. Oscilloscope could be organized with some obstacles.
Thanks a lot!
ColdCoffee
Postby Nicoist » Thu Oct 20, 2011 4:49 am
hi there,
can someone help me on this?
my controller doesn't do anything (no reaction), the led just blinking 6 times. according to the first post this means "hall sensor fault". now when i plug the motor off it does the same. also no reaction when hitting throttle and rotating wheel by hand. cable connections to hubmotor are fine. does it make sense to check and replace the hall sensors inside the motor, or should i get a new controller? thanks
btw have to give away a second defective controller, from germany. it's dead, just sometimes makes the motor buck/cog very short when switched on. optically the board looks absolutely fine. for very little money, if anyone is interested.
Nicoist
Previous
Return to E-Bike Technical
Who is online
Users browsing this forum: icecube57 and 9 guests
