Crystalyte HS3540 disk brake Avid BB7?
Postby Spektrum » Sat Sep 01, 2012 6:46 pm
Hello
I have a crystalyte HS3540 front motor which is mounted on a steel fork.
I wanted to actually install a disc brake and tried two brakes unfortunately also not go.
The brake caliper of the Avid Elixir 5 and the Magura Louise grind on the screws of the side housing .With a 160mm brake disc and with a 180mm disc I've tried it and both times I am failed
I want to like to install Avid BB7 brakes. This caliper between the housing has place?
Thanks
Spektrum
Re: Crystalyte HS3540 disk brake Avid BB7?
Postby scriewy » Sun Sep 02, 2012 3:58 pm
i cant post links from my cell but if you press my nickname you'l see a recent thread there about disk brakes.
take a ruller and measure the clearance you got at your disposle.
bb7 take 17mm of space, and some radius brand mentiond there only 14mm.
usually you just add spacer for the disc to move it away from the hub, and if from that the disc moves too close to the forks leg, you add spacer on axle or play with caliper
it's a pitty i wont stay to see the world crumble, u jedi Scum
clyte 405,
went through battle, bloody resurected Dewalts 4x28v 2s2p usable 2.7ah, 52v drops to 44v at 54kmh
78v 2ah Vdrop to 58v at max 66kmh.
72kg rider + 23kg bike.
keywin 20a 30-70v mod to 6 4110 as methods advised for noobs, shunted 38a
clyte 24-72v 40a mod 4310 to 4110, shunted to 77a
17.5.11 - 5000km
at 78v 4ah 72.7kmh Vdrop to 68v
10.11 - 82.1kmh
30.8.12-17000km
a place for lasers as ES is for e-vehicles - laserpointerforums.com
scriewy
Return to E-Bike Technical
Who is online
Users browsing this forum: DrkAngel, jacobbloy, Seatec and 8 guests
