SHENZHEN Controller Bafang Geared Motor Testing
Postby Knuckles » Wed May 28, 2008 11:05 am
So I just bought a permanent magnet gear reduction (PMGR) planetary-gear brushless Bafang Motor. This motor is in Shenzhen, China in Keywin’s lab. It will stay there until we have thoroughly tested it on the ecrazyman 72V controller. We are trying to reproduce the ‘jitter’ and ‘shift happens’ phenomena as reported by fechter’s most excellent testing.
See viewtopic.php?f=2&t=4282
This is the test motor ...
(153.3 KiB) Downloaded 1901 times
We will post our results (good or bad) here.
Maybe we can get to the bottom of the PUMA mystery once and for all.
cheers
Knuckles
Re: SHENZHEN Controller Bafang Geared Motor Testing
Postby Knuckles » Wed May 28, 2008 5:13 pm
Well Keywin tested it at 72V (exactly 72V) and it ran super fast "like jet engine" says Keywin. Draw 0.8 amps steady at high speed no-load test. We figure 400 rpm wheel speed and 3000 rpm rotor speed. Keywin reported that the motor constant (K) = 50 rpm/V. so 50 x 72 = 3600 rpm max rotational rotor speed at 72V. Testing continues of course.
-cheers
Knuckles
Postby The7 » Wed May 28, 2008 5:35 pm
How many pole-pairs are there in this motor?
What is output frequency from the controller?
The frequency for 1 pole-pair (or 2-pole) motor at 3600 rpm is only 60Hz.
The critical frequency as found by Fechter is about 325 Hz. So this motor needs to be 5 pole-pairs or more to reach the critical frequency at 3600 rpm.
The7
Postby Knuckles » Wed May 28, 2008 5:48 pm
I'll find out.
Knuckles
Postby The7 » Wed May 28, 2008 6:13 pm
It looks as if this is the motor.
This motor has 10 pole-pair. The gear ratio when estimated from picture is about 5:1
If the wheel speed is 400 rpm,
the rotor speed = 400 x 5 =e 2000 rpm.
Then the power frequency = 2000 x10 /60 = 333 Hz.
Now it will reach the critical frequency as per Fechter.
So it is important to know the wheel rpm and gear ratio OR the power frequecncy.
Grubee_04 copy.jpg (52.43 KiB) Viewed 10629 times
The7
Postby rkosiorek » Wed May 28, 2008 7:01 pm
Was this motor previously marketed using the names PARN or TARN? it looks very much like a motor that was tested by various Crystalyte dealers 2 years ago.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby Knuckles » Wed May 28, 2008 11:43 pm
The7 wrote:How many pole-pairs are there in this motor?
OK. Keywin says ...
... There are 10 pole pairs
... The gear ratio is 1:4.3
... and "i am sorry, 2400 rpm at 48v is not bafang. 1720 rpm at 72v is bafang motor"
(hopefully this data is much closer to correct than before ... gotta LOVE China!)
I guess that means the motor (rotor) constant K = 1720rpm/72V = 23.9 rpm/V
Heck I own the darn test motor. You want I tell Keywin to try a no-load test at 100+V? Just to see the jitter?
btw ... this statement by you (The7) "Apparently the board of this controller was designed on the understanding that the power frequency will never exceed the critical frequency (about 325 Hz) which is valid for gearless hub motors."
Well you may be on to something. Keywin writes the code and he got quite 'perplexed' by this concept.
HMMM. The plot thickens!
Elementary My Dear Watson! Quite so Mr. Holmes! Ay, that's remarkable! (But WTF are you talking about?)
Knuckles
Postby The7 » Thu May 29, 2008 1:16 am
Knuckles wrote:OK. Keywin says ...
1720 rpm for 10 pole-pairs => 1720 x 10 / 60 = 286 Hz which is lower than the critical frequency by 13%.
Perhaps 82 V could run this motor into the critical frequency.
Knuckles wrote:Heck I own the darn test motor. You want I tell Keywin to try a no-load test at 100+V? Just to see the jitter?
Why not? Would like to hear the results at 82 V as well.
Knuckles wrote:btw ... this statement by you (The7) "Apparently the board of this controller was designed on the understanding that the power frequency will never exceed the critical frequency (about 325 Hz) which is valid for gearless hub motors."
Glad if Keywin could tell us the following since he wrote the code: ( Otherwise I would be more perplexed)
a) Is there any overspeed limit program written in the code?
b) What is the expected limit of the operating frequency ?
The7
Postby docnjoj » Thu May 29, 2008 7:13 am
So after all the math (my favorate subject) would it be fair to say that these gear motors would be fine with either Keywin or Crystalyte controllers at "normal" voltages, like 36-48??????
otherDoc
Wife is getting a trike to keep the ER visits down. Current one was pretty bad! New trike on the way! Sun USX although she weighs a lot less than the max weight! I am the proud rider of a Steintrikes Mad Max full suspension trike with a 9C motor. Tricruiser trike in semi-retirement after 9 years of loyal service.
Now running on 6 Fatpacks at 54 volts and 8 ah!
36 volt 20 ah split-Ping looking for a new project prolly wife's new trike power.. or 54 volts if she has the "need for speed"!
docnjoj
Postby fechter » Thu May 29, 2008 9:42 am
With the Puma motor (and I assume the BMC would be similar), I can hit the critical frequency at around 30v. Below this voltage, you won't have any problem.
fechter
Postby Knuckles » Thu May 29, 2008 9:43 am
docnjoj wrote:So after all the math (my favorate subject) would it be fair to say that these gear motors would be fine with either Keywin or Crystalyte controllers at "normal" voltages, like 36-48??????
otherDoc
I think this is a fair statement for the Bafang PMGR motor. If you operate it below the critical frequency then all should be fine.
Knuckles
Postby Tiberius » Thu May 29, 2008 9:51 am
Hi Knuckles,
Is this a rear wheel or front wheel motor? Can you tell us the part number?
I may be in a position to run similar tests?
Nick
Winner of Tour de Presteigne 2009
Tiberius
Postby Knuckles » Thu May 29, 2008 1:16 pm
It's a front wheel motor. I don't have the part number (motor is in China now, not with me in NY) but you can see some of the numbers in the photo at top of thread.
I just had a thought. Would a 'pedal first' controller be immune from the 'critical frequency' limitation when running a PUMA or BMC motor?
Or would it suffer the same 'jitter' at a critical rpm?
Heck if a 50-amp 72V controller was made without the need for Hall Sensors (pedal first) and it did not suffer from 'the jitters' then this could be a nice alternative.
I posted this question here as well ... viewtopic.php?f=2&t=3896&start=135
Knuckles
Postby docnjoj » Thu May 29, 2008 1:57 pm
The problem with "pedal first" is that U have to. If U R stuck on a hill in the wrong gear, U have to go back down just to turn on the motor! No thanks!
otherDoc
docnjoj
Postby tostino » Thu May 29, 2008 2:23 pm
Yeah, i'd not like a pedal-first controller as a solution, because I am going to be making detachable pedals, and not running with them all the time.
That would be more of a hack-job rather than a real fix.
tostino
Next
Return to E-Bike Technical
Who is online
Users browsing this forum: gtadmin and 1 guest
