pucksterpete
I am having trouble with getting the 3 speed switch to actually run 3 different speeds.
I have the controller Lyen 24fet 4110 configured with spd1 34%, spd2 66% and spd3 99%
Now, when I go to run a no load test speed 1 & 2 are the same, but 3 is faster, then when I switch back to speed 2 or 1 they have become what speed 3 was.
If I set the controller to 99% for all the 3 speeds, then the switch is 99% on speed for the 3 settings.
I would like to have 3 different speeds if I can.
I tried a few different combinations of changing the pin configuration on the connector for the controller, but got pretty much the same result.
Any ideas?
Pic below from test profile, running 67V
Any ideas?
