lifepo4ever said:
Experience from ES members is better
I'd agree that's the case for those who don't know how to interpret data and graphs :wink:
To answer your original question as to the most efficient 9C motor. In theory the 8x8 winding has the most copper fill factor at 64 strands*2 per slot, while the other popular winds (9x7 and 10x6) are a tad less at 63 and 60 respectively. In practice, the resulting difference is so small as to be completely undetectable, and even with good equipment also unmeasurable. The peak efficiency of all the winds is basically the same within any margin of measurement error.
If your metric for
efficiency is wh/km rather than the ratio of input to output power on the motor, then the most efficient motor is going to be the one that encourages you on average to go at a slower speed. Up to a limit, the slower you ride the better your range and mileage. So in that sense, the 2808 will seem more 'efficient' than the 2807 or 2806 just because you won't be going as fast.
-Justin
