gwhy!1
Thought I would quickly post this up as it may be of use to some one. The fuse in side the fuse holder can be anything upto around 200A the resistor value is a 180ohms 3w. the link could be a pullable link so it will cut all power to the controller in a emergency and it will shunt the bike power down, it is a lot more compact and much cheaper than using a contactor as a quick disconnect but the batterys do still have to be disconnected when the bike is not in use... This lead is made up with 8awg and 6mm connectors
