Efficiency?
DrkAngel
Re: Efficiency?
Post by DrkAngel » Dec 05, 2016 10:05 am
Highlights & Index
Attack Them Hills!
Determining Peak Motor Output - Simple-Cheap Method
Electrical Input Watts vs Motor Output Watts
Motor Output Watts vs Speed - Aerodynamics
Motor "Watts" ... Input or Output?
Speed vs Range
Winter efficiency(?)
Well, getting acceptable use from batteries during cold weather.
See - Batteries vs Cold
  • Discusses:
  • Battery performance loss when cold
  • Keeping battery warm
  • Larger capacity battery to offset cold
  • Capacity not diminished as much as IR (Internal Resistance) is amplified, by cold
  • etc.
Index - Homemade Battery Packs - Updated - November 2015
EBike Toolbox - Bargains! $
Endless Sphere Wiki
DrkAngel
Re: Efficiency?
Post by DrkAngel » Dec 13, 2017 8:09 am
This thread has been idle so long it's pretty much fallen off the charts.
Been resurrecting an old hub motor and the issue of efficiency raises it's head ...
Rescue Motor - Aotema (Wilderness Energy BD-36)
Mapped the power curve of a 2005 era BD36 front hub motor.
(Volts, Amps and tire size modified to match actual performance curve.)
26" wheel vs 20" wheel
Yes 20" for 20mph @ 36V looks optimal!
Simply resizing by the proper ratio (36" / 26" x 20" = 27.7") I was able to plot motor with 20" wheel.
Full throttle:
drops speed from 23mph >> (legal) 20mph;
improves efficiency from 72% >> 80%;
improves hill (below 12mph) and starting (35lb >> 45lb) torque;
increases range from 23 miles to 32 miles!!!
Proper 20" front wheel application is the problem!
Small 20" trike?
Will test alternate voltages before deciding anything ...
Endless Sphere Wiki
marvak
Re: Efficiency?
Post by marvak » Dec 25, 2017 4:47 pm
Hm, I search optimal efficiency, and find 420 results
Probably should smoke more
DrkAngel
Re: Efficiency?
Post by DrkAngel » Dec 27, 2017 10:13 am
Aerodynamics as the major factor in efficiency
Using the same WE motor simulation, I compared MTN Upright vs MTN Tuck. Presumably the is an upright seated posture vs a crouched down over the handlebars position.
vs Tuck.jpg (214.71 KiB) Viewed 166 times
Note the increased range at the increased speed!
23 miles@23mph vs 30 miles@24.5mph
More reasonable, and impressive, in my opinion, is the comparison when both are throttle regulated at 20mph!
29 miles vs 41 miles range!!!
Comfort is the drawback, especially with prolonged range. I have experimented with using a large low comfort seat, then sat behind it on the rack, resting midsection on seat and using seat against legs as something of a seat belt, holding me back and stable during braking.
Padded motorcycle type seat extending onto rear rack is the next logical step, then drop handle bars.
Alternately, the application of some form or degree of fairing should prove similarly effective!
See also - Aerodynamic Factors
Endless Sphere Wiki
DrkAngel
Re: Efficiency?
Post by DrkAngel » Dec 30, 2017 5:07 pm
Implication of wind as an efficiency factor seems to, obviously, demonstrate that a more aerodynamic positioning is more efficient than the assist applied by pedaling from a more upright seating posture ... dependent on cyclist capability, of course.
Somewhere between 20 and 30 mph a more aerodynamic posture out performs the continuous capability of pedal assist.
20mph = ~80w differential
30mph = ~300w differential
Not that I am recommending against pedal assisting!
  • Pedal assist is instrumental in:
    Getting up to speed
    Going up hill
    Casual cruising, where range is greatly extended
    In traffic, where better vision and acceleration are essential
Endless Sphere Wiki
