48v 1000w controller help
skeltonh
Post by skeltonh » Jun 09, 2014 10:58 pm
I have a 48v 1000w controller that is the closest match I have found to the original controller that came with my motor.
Model: KT48ZWSL-ZC14A
The old one was a KT48ZWL.
The main problem I have is I have no writing specs for either. Most of the connections are universal but the throttle connection differs and there are two connections that I am unsure of. On the old throttle the connection has six wires. In the new one, only five.
See attachment for picture of new controller.
[attachment=-1]uploadfromtaptalk1402372582605.jpg[/attachment]
I need this bike up and running as it is my commuter bike. While I could have waited more than a month for the slow boat from China I choose local, fast, and what I could afford.
Hopefully someone here can point me to the information I need.
Thanks!
wesnewell
Re: 48v 1000w controller help
Post by wesnewell » Jun 10, 2014 12:30 am
What you have labeled as the throttle in your photo is actually a second hall sesnor connector. What you have labeled "Red Green Black?" should be the throttle connection. Red and black for power and green is the sense wire. Might want to wait for a second on that, but I'm pretty sure that's right.
mlt34
Post by mlt34 » Jun 10, 2014 12:33 am
wesnewell wrote:What you have labeled as the throttle in your photo is actually a second hall sesnor connector. What you have labeled "Red Green Black?" should be the throttle connection. Red and black for power and green is the sense wire. Might want to wait for a second on that, but I'm pretty sure that's right.
I agree. Though I'm not sure that is a second hall sensor connector - it might be a display. Either way, your red/green/black is almost definitely your throttle connector.
Your old throttle probably had LED's to tell you how much battery you had left, right? And maybe some form of button or switch? That's why it had six wires. This controller uses just a simple throttle, no fancy lights or switches. To connect it, you'll need to wire just your red (+5V) wire and black (ground) wire, plus your signal wire. If you had six wires on your throttle, your signal wire is likely either white or green. I've seen blue, but it's rare. If in doubt you can just try them all (except black and red) with alligator clips until you find the one that is the signal wire. If you connect the LED or switch wires, nothing will happen and that's how you'll know its not the signal wire.
That other three pin connector, black red and grey i think you wrote, that's your pedal assist PAS connector.
Are you planning your first electric bicycle conversion? I wrote a book that teaches beginners everything they need to know about building their own ebike.
Then I wrote the book (literally) on building custom lithium batteries.
I also write for EbikeSchool.com, a site that does mainly how-to style articles and other informational write-ups. Check out our youtube channel for great how-to battery building videos.
Lastly, I run www.Vruzend.com, which sells solderless 18650 battery kits, 18650 cells, li-ion chargers, BMSs and more!
Dauntless
Post by Dauntless » Jun 10, 2014 12:57 am
That's not your writing, is it? Aliexpress has postings with pictures labeled that way.
All sorts of possibilities, but you'll solve it by guessing right.
http://www.ebay.com/itm/NEW-Razor-24v-1 ... 0846895801
http://www.ebay.com/itm/NEW-4-wires-Thu ... 0659249498
Don't remember if there were 4 wire curries in the past, razor uses 4 wires.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
skeltonh
Post by skeltonh » Jun 10, 2014 5:43 am
The bike may be a Currie but it has since been updated with the Chinese drive. I'll see about the three wire throttle and see how that goes. I agree that the other wide connector might be a display. The other three wire might also be the speed setting. I've seen those on some of the same brand controllers. (Low, Normal/Medium, High). I just don't want to blow something when I hook this up. Presently I have to get some parts to hook up the motor wires and am trying to get the power hookup for the 12v circuits and hide all the snakes in one box to make a more stream lined look. As long as I get the motor running and gets me to work then I'll be happy.
skeltonh
Post by skeltonh » Jun 10, 2014 5:48 am
wesnewell wrote:What you have labeled as the throttle in your photo is actually a second hall sesnor connector.....
If it is a second hall sensor connector, and my motor does not come with one, do I need to find a different controller?? Or can I use it without connecting it? I would think it exists for a reason and that I might have wasted money on a controler that does not fit my needs.....
mlt34
Post by mlt34 » Jun 10, 2014 8:56 am
I could be wrong, but I really don't think it would be a second sensor connector. Why would it be needed anyways?
And don't worry about blowing anything in the controller when connecting your throttle and searching for the signal wire. Since your other throttle wires are just LEDs and a switch, nothing bad will happen if you connect a non signal wire to the controller's throttle signal wire (except for the red and black, don't connect those to anything but the red and black controller throttle wire).
let us know how it goes.
wesnewell
Post by wesnewell » Jun 10, 2014 10:58 am
skeltonh wrote:If it is a second hall sensor connector, and my motor does not come with one, do I need to find a different controller?? Or can I use it without connecting it? I would think it exists for a reason and that I might have wasted money on a controler that does not fit my needs.....
I plead ignorance as to the reasoning behind double hall sensors. I just know there are motors that use them. I would think you just leave one of them unconnected if your motor doesn't have them. Here's one motor that has them.
http://www.cnebikes.com/ProductShow.asp?ID=133
mlt34
Post by mlt34 » Jun 10, 2014 11:11 am
wesnewell wrote: Here's one motor that has them.
Interesting. I see that motor is meant for high power/high voltage. I wonder if they assume with that higher heat generation that there's a better chance for hall sensor damage so they double up?
skeltonh
Post by skeltonh » Jun 10, 2014 10:54 pm
Found out the five wire "second hall sensor" cable is actually a Cycle Analyst and PAS control Panel wire. It requires a control panal that is compatable. Some are five wire, others are six. Mine is five. Now if I can only find the pins to cross to "Turn On" the bike.... Hooked everything else up but that plug. Guess I'm going to have to dig to get the control panel for the controler if I'm ever going to get to ride again.
mlt34
Post by mlt34 » Jun 11, 2014 1:55 am
On a number of controllers I've worked with, it's been a cross between red and blue on the display connector. The problem is that every controller manufacturer is different and so that doesn't mean you can count on that for your controller… :-/
Avitt
Post by Avitt » Jun 11, 2014 8:33 am
That 5 wire connector is the same one used on other KT controllers to connect an LCD or LED display. My guess is that it will work with a KT-LCD1 display (or an S-lCD1, from bmsbattery,com).
You should also be able to jumper some pins, to use the controller without a display. But you will then have no control over the various available parameters.
skeltonh
Post by skeltonh » Jun 13, 2014 6:54 am
Avitt wrote: You should also be able to jumper some pins, to use the controller without a display. But you will then have no control over the various available parameters.
no luck with that. the manual in the panels show a control lead, and two data leads,plus usual power leads. guess it is all data driven...
mlt34
Post by mlt34 » Jun 13, 2014 7:22 am
Even so, isn't jumping power to one of the data wires the way it's done? On the controllers used on many bikes in my country, they have a 4 pin display, and you circumvent it by shorting the red and blue wires (positive and one data wire). Your mileage/controller may vary.
Flaghole
10 µW
10 µW
Post by Flaghole » Jun 16, 2014 7:30 pm
Your controller looks similar to the wiring diagram I saw at the Leafmotor website for their BLDC Motor Controllers.
Avitt
Post by Avitt » Jun 16, 2014 11:43 pm
See this:
https://www.bmsbattery.com/attachment.p ... achment=53
...I don't think it's a coincidence that the 5 pin LCD/LED has the same wire colors as your controller. If this is like other KT controllers, you'll need to short red to blue, and black to yellow.
skeltonh
Post by skeltonh » Jun 17, 2014 5:42 am
Tried it. No luck so far. About to disassemble the controller to see what is going on inside. Other than that I may have to find a simple controller that will get me mobile again. I cannot stay offline like this. This is money I can't afford to keep spending.
skeltonh
Post by skeltonh » Jun 17, 2014 6:28 am
Just a thought: where can I buy just the LCD Control Panel for this controler. I don't see where I can buy just it without a controller.
Many thanks. :D
mlt34
Post by mlt34 » Jun 17, 2014 6:49 am
skeltonh wrote:Just a thought: where can I buy just the LCD Control Panel for this controler. I don't see where I can buy just it without a controller.
Many thanks. :D
http://www.bmsbattery.com/controller/54 ... meter.html
http://www.bmsbattery.com/controller/67 ... meter.html
Flaghole
10 µW
10 µW
Post by Flaghole » Jun 17, 2014 7:28 am
mlt34
Post by mlt34 » Jun 17, 2014 10:39 am
Flaghole wrote:http://m.ebay.com/itm/141294791893?nav=SEARCH
This seller is in U.S.
ooo us sellers are always better. nice find.
I didn't know about this 'ebikeling' seller. Do others? People work with him before? Seems to have a lot of stuff, and even branded 9C clones. Makes me think it isn't a small operation if he has his own branded 9C's, even if it is the old style case.
skeltonh
Post by skeltonh » Jun 17, 2014 11:01 am
I got my controller through them. No documentation. No support. Just sells items.
mlt34
Post by mlt34 » Jun 17, 2014 1:34 pm
any idea what kind of controller? and are you happy with it?
skeltonh
Post by skeltonh » Jun 17, 2014 2:33 pm
48v 1000w KT type. Haven't found documentation for it. Seems to not want to run without the control panel, but they don't tell you this. I have yet to get mine too run. Considering a proven alternative but I'm really strapped on money, big time. Don't want to have my investment not work but sometimes guano happens...
