Will this Hall sensor do, as a replacement?
JayS
Sydney, Australia
Hi Fuelsavers,
A Hall sensor in my dd hub has failed and I was wondering if I could get some advice on a replacement sensor.
My failed sensor is a Taiwan Semiconductor
TSH181CT and they're a little bit hard to find.
TSH181CT newsletter
http://www.taiwansemi.com/admin/ckf...letter 13-2013 TSH-Series Hall sensor-(2).pdf
TSH181CT datasheet
http://www.ts.com.tw/DSfile/TSH181_B13.pdf
TSH181CT product page
http://www.ts.com.tw/home/en/products/product_info.php?partid=TSH181CT
I thought I may be able replace the failed Hall with a Honeywell SS400 series, the SS411A.
http://docs-asia.electrocomponents.com/webdocs/002e/0900766b8002e123.pdf
suitable?
recommend another?
do I have to replace all three sensors?
Thanks for your time.
The ss411a is the hall sensor of choice for most of our motors. Every time mine have failed I've replaced them with these- sometimes I couldn't even see what the old ones were.
Couldn't tell you if it's exactly the same specs as the one that came out tho- cbf to read the specs sorry. I've had a couple of somewhat generous gin&tonics so my interpretation of the specs may be off anyway... :shock:
