Known to Work Brushless Motor/Controller Wiring Diagrams
Postby fechter » Wed Sep 03, 2008 8:53 am
Like the topic states, post your known to work brushless motor to controller wiring diagrams here.
Well, I'll start with a no-brainer. A Crystalyte motor to the old analog Crystalyte controller, all the colors matched up, amazingly.
My sample of a Puma motor (may not be typical) to a Crystalyte analog controller looked like this:
Motor :arrow: Controller
Phase wires:
Blue :arrow: Green
Green :arrow: Blue
Yellow :arrow: Yellow
Hall sensors:
Blue :arrow: Yellow
Green :arrow: Green
Yellow :arrow: Blue
Edit: reverse jumper open.
(edit to add keywords for search engines to find easier:
phase hall wire combination combo
phases halls wires combinations combos )
fechter
Re: Known to Work Brushless Motor/Controller Wiring Diagrams
Postby The7 » Wed Sep 03, 2008 10:24 am
Please also state whether the "reverse' link is CLOSE or OPEN if there is such a link in the controller.
The7
Postby Nogwin » Wed Sep 03, 2008 5:30 pm
My sample of a BAFANG motor (from knuckles) to a Crystalyte analog controller 36-72v 35A looked like this:
reverse jumper open
My motor wiring combo
Motor Phase -- Controller
B :arrow: B
G :arrow: Y
Y :arrow: G
Hall
pos :arrow: pos
neg :arrow: neg
B :arrow: B
G :arrow: Y
Y :arrow: G
This was the only combo that worked for me.
This is for Xlyte (old analog style) 36-72v 35A controller
Nogwin
Postby voicecoils » Thu Sep 04, 2008 7:19 am
If anyone has the known Bafang PMGR to old ecrazyman 72v 28A 1000w controllers (I think knuckles is calling them the "pic based" ones) I'd like to know it. Cheers!
voicecoils
Postby HAL9000v2.0 » Thu Sep 04, 2008 7:35 am
Crystalyte 504 & Kelly KEB72331
X504 Kelly
Motor:
blue :arrow: A
green :arrow: B
yellow :arrow: C
Hall:
yellow :arrow: A(pin13)
blue :arrow: B(pin12)
green :arrow: C(pin11)
red :arrow: +5V(pin7)
black :arrow: GND(pin2 or 3 or 14 or bat- all is connected internaly)
Throttle:
black :arrow: +5V(pin7)
green :arrow: GND(pin2 or 3 or 14 or bat- all is connected internaly)
yellow :arrow: throtle signal (pin5)
red :arrow: not used
HAL9000v2.0
Postby docnjoj » Thu Sep 04, 2008 8:00 am
Does anyone know if the 20 amp model instant start analog 36-72 volt Crystalyte controller has a reverse jumper? Picture?????
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby HAL9000v2.0 » Thu Sep 04, 2008 9:03 am
Yes, it has...
HAL9000v2.0
Postby docnjoj » Thu Sep 04, 2008 9:06 am
Thanks HAL! Does the reverse circuit run slower/faster than forward circuit?
otherDoc
docnjoj
Postby HAL9000v2.0 » Thu Sep 04, 2008 9:14 am
same. just changes sequence by flipping two fazes...
HAL9000v2.0
Postby docnjoj » Thu Sep 04, 2008 9:24 am
Ah ha! Thanks again HAL!
otherDoc
docnjoj
Postby rkosiorek » Thu Sep 04, 2008 9:32 am
it runs at the same speed. it just reverses the motor direction.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby docnjoj » Thu Sep 04, 2008 9:54 am
My BAFANG geared motor (from knuckles) to a Crystalyte analog controller 36-72v 20A looked like this:
reverse jumper open
B :arrow: Y
G :arrow: G
Y :arrow: B
Hall
pos :arrow: pos
neg :arrow: neg
B :arrow: B
G :arrow: Y
Y :arrow: G
This is for Xlyte (old analog style) 36-72v 20A controller
I tried Nogwins wire combo and the motor ran backwards! As U all are aware, my combo runs at higher than normal current (12 A) free running at 42 volts. I am awating an Infineon to test whether it lowers free running amps. The motor behaves normally when a load is placed (like me riding up a hill) and current drops significantly on level ground (3-6 amps)
docnjoj
Postby docnjoj » Sun Sep 07, 2008 9:19 am
My BAFANG geared motor (from knuckles) to an Infineon 36-54 volt controller. This is one of 3 "known good" combos that Knuckles has on a new spreadsheet.
reverse jumper open
B :arrow: B
G :arrow: Y
Y :arrow: G
Hall
pos :arrow: pos
neg :arrow: neg
B :arrow: B
G :arrow: Y
Y :arrow: G
There are 2 other combos that work. No load down to <1amp! Smooth as silk! Much better than old Crystalyte above! :)
otherDoc
docnjoj
Postby voicecoils » Thu Sep 11, 2008 7:00 am
Bafang PMGR and older pic based ecrazyman controller (72v 28a 1000w model):
B Y
G G
Y B
Hall
Motor Controller
pos pos
neg neg
B B
G Y
Y G
As suggested to me by Knuckles. Phase set to 120 deg (jumpers open)
voicecoils
Postby fechter » Thu Sep 11, 2008 8:12 am
Connecting an ecrazyman controller to a Crystalyte X5 motor:
dirtdad wrote:I have had both controllers wired to a 5304, wiring is the same for both. Of course there are 6 working color combinations, this is just one, and matching colors does not work. To be thorough and cover even the more obvious stuff:
Infineon 45A/
Original 28A X5
Phase Wires
Blue Yellow
Green Green
Yellow Blue
Hall Sensor Harness
Blue Green
Green Blue
Yellow Yellow
Red Red
Black Black
3 Wire Throttle
Red Red
Green Green
Black Yellow
By the way, the Infineon has proven to be the most reliable controller I have had so far, it throws off little heat and can pump 72V and sustained 20-30A all deliver 40-45A easily when you need it. I have tested the 36/72V plastic shell Crystalyte, the Wilderness Energy, and both of these controllers.
fechter
Postby markcycle » Sat Sep 13, 2008 10:23 pm
This is what I'm using with a 5302 and a Kelly KEB72601
Motor: A blue / B green / C yellow
Hall: A yellow (13) / B blue (12) / C brown (11)
seems to work for me
The Kelly is louder that the Crystalyte at very low RPM's but at 2 or 3 MPH smooths right out.
Mark
Edit: Oh I didn't know Fechter already posted it sorry for the duplication
markcycle
Postby snowranger » Thu Oct 16, 2008 11:25 am
ECrazyman 48 volt Infineon to BMC hub motor
This is what worked for me. Thanks knuckles for the testing procedure. I blew two safety fuses in the process.
Phase Controller to Motor
B-B
G-Y
Y-G
Halls Controller to Motor
B-B
G-Y
Y-G
snowranger
Postby drunkencat129 » Thu Nov 13, 2008 2:18 am
to fined out the hull fireing order what i did was put 1 led in searies between each hall color and spin the motor the motor slowly when the controller is on DO NOT OPEN THE THROTLE then u can see what led fires in what order that will narow it down to the halls just compair it to ur other motor that was runing and ur all good match the order and u only need to fool with the 3 phase wires :P o and dont for get to remove the adapter if u end up makeing one lol
fechter wrote:Like the topic states, post your known to work brushless motor to controller wiring diagrams here.
Phase wires:
Blue :arrow: Green
Green :arrow: Blue
Hall sensors:
Blue :arrow: Yellow
Green :arrow: Green
Yellow :arrow: Blue
drunkencat129
KELLY KBL WIRING
Postby methods » Wed Jan 28, 2009 12:11 am
Connecting hall sensors to a Kelly controller
(as promised to Fechter months ago) :|
Motor: 5305
Controller: Kelly KBL 12221H 120V 220A
All KBL are the same
HALL SENSORS:
X5______Kelly J2______Desc.
1 ---to--- 7 _______+5V
2 ---to--- 3 _______GND
3 ---to--- 11 ______Phase C
4 ---to--- 12 ______Phase B
5 ---to--- 13_______Phase A
MOTOR PHASE WIRES:
X5______Kelly
Blue_____Phase C
Yellow___Phase B
Green___Phase A
Tips for nOObs:
* TPS Switch is not used. Disable it or tied it to ground. It is a high pedal switch for a fork lift
* TPS analog is your throttle
* Brake switch goes to your ebrakes
* Brake analog is a variable brake. I dont use it. Just set the regen to brake to your desired level with the hand switch
* The voltages and currents are not perfect. Tune them in. DONT trust the LVC
* Current is MOTOR current
* If you dont own a CA then dont hook up this controller
* Pay the $19 for the J2 wiring cable. It will change your life from hell to heaven. All potted, labeled, bundled, and ready to go. Best thing ever.
* Download the newest firmware (Feb 09 it is V209)
* Spend time with the software to learn it
* Turn down the "rate" of the throttle for a more smooth response
* Fine tune the throttle end points
* Explicitly try Torque mode, Speed mode, and mixed mode
* Avoid TPS throttle
* Ask before you get frustrated
* DON'T PM me with questions. Ask in a thread or start a new thread and PM me to get my attention.
* Understand the schematic before wiring. It is a little confusing
* Ground is common. Never fuse it.
* Learn how to read the error codes
* If your new install is loud then your halls may be out of phase
* Please ask questions in the forum before claiming your controller is broken and sending it back
* If you are considering a Kelly but are not a DIY person look elsewhere. It is complicated to wire. This is NOT an xlyte plug and play.
Thats all for now.
I wish all new Kelly owners luck.
For the record, Kelly is the best company you could ever want to do business with. 100% guarantee on the controllers. No questions asked in the case of a problem. You ship it back and they ship one to you. Brand new same day. You cant beat that. Steven answers emails fast. If you want a no-nonsense controller that kicks ass this is the one for you. Mine has never even gotten warm under 100V 60A cont. use. I launch at 190A and no problems. Firmware updates are often so you dont have to worry about problems.
-methods
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
Re: KELLY KBL WIRING
Postby markcycle » Wed Jan 28, 2009 12:41 am
methods wrote:Connecting hall sensors to a Kelly controller
Motor: 5305
HALL SENSORS:
MOTOR PHASE WIRES:
X5______Kelly
Blue_____Phase C
Yellow___Phase B
Green___Phase A
Tips for nOObs:
Thats all for now.
-methods
Wow that's different than what I'm using and what other people have used got to give it a try
Motor: A /blue B/ green C/ yellow
markcycle
Postby methods » Wed Jan 28, 2009 10:19 am
This stemmed from getting it wrong in the beginning.
I had to try different combinations till I got it to work.
Maybe I will try your combo this go around.
-methods
methods
Postby Knuckles » Thu Jan 29, 2009 12:32 pm
Anyone know the hall/phase color combos for the Infineon to a X-Lyte 5304?
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby fechter » Thu Jan 29, 2009 2:36 pm
Knuckles wrote:Anyone know the hall/phase color combos for the Infineon to a X-Lyte 5304?
It was on the bottom of page one:
Infineon 45A/Original 28A :arrow: X5304
Phase Wires
Blue :arrow: Yellow
Green :arrow: Green
Yellow :arrow: Blue
Hall Sensor Harness
Blue :arrow: Green
Green :arrow: Blue
Red :arrow: Red
Black :arrow: Black
fechter
Postby nicobie » Sat Jan 31, 2009 1:42 pm
Thanks Fechter.
Knuckles was asking for me. I'm trying to match a controller with my 600w BMC motor. So far all I know is that a GM one won't work.
Nick
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Postby dogman » Thu Feb 26, 2009 6:48 am
Wilderness energy motor to Crystalyte pedal first controller.
Another easy one, the colors match. No hall sensors on the motor to worry about, so this motor has to have pedal first.
THE LIPO RULES. NEVER ABOVE 4.3V NEVER BELOW 2.7V DON'T PUNCTURE
Ideal charging /discharging range for Lipo, 3.65v minimum 4.1v maximum
See battery technology section, FAQ thread at the top of the page for lipo noob info.
dogman
Next
Return to E-Bike Technical
Who is online
Users browsing this forum: chris1968, chroot, justforfun and 10 guests
