by pdf » Wed Mar 09, 2011 5:27 pm
I have a 9c controller, 36v, 27 amps, and a 9c motor. Both have male plugs (??) for what I assume are the hall sensors, black, blue, green, yellow, red. The connector is a 5 pin linear arrangement. There are also two identical connectors coming from the controller with two female three pin terminals but only two are connected to wires; the wires on both are black and yellow. There are also a black wire and white wire, each with its own one pin connector, one female, one male, that are plugged into each other. My questions are:
1) If I am correct about the hall terminals, does anyone know of a female-female sex-swapping jumper to switch one of the male to female? The controller came with an extension, but it is male on one end and female on the other
Otherwise, I have to find this exact connector and cut and remake one female or cut off both and use a 5 pin connector I can get locally.
2) Does anyone know what the other connections are for, that is the two two-pins with black and yellow leads or the black and white connected together? The controller label says: "Function: Automatic cruise, E-ABS, Energy feedback, Mute" I'm guessing the two two-pins are for the e-ABS. Not sure what the black, white connected pair are for.
Jamis Commuter 1.0/Xtracycle Stokemonkey 36V LiFePO4, 15 ahr
Giant Boulder 9C 6x10, 18s1p LiPO, 5 ahr, 18FET Lyen edition
