Doctorbass
I am working on building an inductor ( choke coil) fo rthe Adaptto controller charge option.
I just wonder witch way is better if i want to use multiple parallel strands
. LItz wire or not? ( a stranded wire with individually insulated conductors (forming a bundle)
Is it better to twist the multi parallel strand bundle (litz wire) prior to install it on the core or not to twist the bundle of wire and just turn them on the coil?
These wires in the bundle are twisted together (Litz)
ex:
In this exemple these are not ( like in our hub motor):
Thanks in advance.
Doc
ex:
Thanks in advance.
Doc
