New Open Source E-Bike/E-vehicle calculator & simulator
Re: New Online E-Bike/E-vehicle calculator - Beta testing/Debug
Postby michaelplogue » Thu Oct 30, 2008 2:48 pm
I just tried the latest version you posted(EbikeCalc2.jar) - it won't work on my XP system now [error:Java Virtual Machine Launcher "Could not find the main class"].
I just checked, and the earlier version still works on this computer.
http://nws.carbonmade.com
Goped ESR Super Extend Range (S.E.X): 24V 30AH SLA
Diggler FS: Xlite 5303, 36V 40AH LiMn
Schwinn Spoiler chopper bicycle: Ezee front motor, 48V 30AH LiFePo4 (under construction)
Kikker Hardknock motorcycle: Etek-RT, Kelly PM72401, BMI 60V 60AH
Build Thread: http://endless-sphere.com/forums/viewtopic.php?f=10&t=6972
michaelplogue
Postby Mathurin » Thu Oct 30, 2008 2:59 pm
Still sorta works at my end:
(36.68 KiB) Downloaded 2482 times
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
Mathurin
Postby swbluto » Thu Oct 30, 2008 6:46 pm
That's a quirk of the program. If you're past 80% of the no-load RPM using one of the preloaded hub motors, it draws a line from the efficiency at 80% to an assumed 0 percent efficiency at the no-load RPM and then guesses based on that. To correct that quirk, I'd have to know the no-load currents of the various hub motors(You see that the program currently assumes a no-load current of 0 amps for the hub motors which is, well, clearly wrong.).
Also, 26.3 cm is pretty small for a wheel diameter... :wink:
Anyways, I'll look into that "main class" problem. It might be a problem with how I set the program up(It probably is). Edit: I did some testing and it appears it comes up with that error if you don't preserve the folder structure inside the zip-folder(i.e., the "lib" folder is in the same folder as the EbikeCalc2.jar file, and the "lib" folder has the "swing layout" file. The zip file must be extracted/unzipped.). I think I may just create an installer for future releases just so this set-up problem doesn't occur.
DO NOT BUY FROM ELECTRICSCOOTERPARTS . COM! They are DAMN THIEVES! They will happily take your money, not send you the product, and then claim because you didn't mention something within 15 days (Hello, mail can sometimes take longer than 15 days), they've lost all records and thus they can't help you out.
Check out the latest version of the FREE e-bike/e-scooter( or anything that uses a single brushless or brushed motor) simulator.
swbluto
Postby swbluto » Tue Nov 04, 2008 2:35 am
I've found a fatal flaw with the program. If the throttle is less than 100%, it won't do predictions accurately. The further away it is from 100%, the more inaccurate it is. Just a heads up.
I'm in the process of correcting the problem and expect to have a release in 2 days(November 5th). Stay tuned folks! I think some will like it. :wink:
swbluto
Postby swbluto » Wed Nov 05, 2008 7:15 pm
Here's what I have so far. The link to the .zip is below and the self-extracting .exe(which avoids possible set-up problems) can be found here. I've found out macs can't use .exe files(or can they?), so the zip file below is provided for those that have systems that won't work with .exe(or whatever platform winrar didn't target).
The graphing feature is in its early stages. Each variable has its own axis so if you want to know its value, look at the corresponding axis. The different force curves nor current curves are aligned, so don't assume that where they intersect on the graph is the true intersection so make sure to look at the axis. I'll try to get those aligned, but from my power curve attempt, it doesn't seem like I've mastered it yet. Also, the efficiency curve and power curve must be shown since... well... I'm still learning how to make everything optional. Also, the efficiency and heat generation curves aren't accurate near the no-load speed for the hub-motors but they are(or should be) accurate for everything else that has a no-load current. If you happen to know the K, Rm and Io for any of the hub motors, feel free to customize and make sure to tell me what it is so others can benefit!
Also, the optimization feature requires every parameter to be filled in, even for the parameter being varied('cuz I'm too lazy to make it work without it. Just enter any number in the boxes at the top and it should work.). The optimization works by dividing the range of values you request it to test into many different sample points, samples them, and then finds the maximum(or minimum) result of whatever you're wanting to optimize(say speed or efficiency.) and reports back in the message box. The "steps" box basically asks how many different samples you want to test: The more steps, the more resolution/greater-accuracy it'll have but it'll also take longer. My computer starts bogging down past 1000 steps, but it seems some of the newer computers can easily/quickly handle 10,000 steps. It doesn't do any error-checking, so don't be surprised if you may get back negative numbers when requesting the minimum. All I have to say is adjust the min and max so they're "realistic.". You're not likely going to use the throttle at 2% since that's not enough current to overcome the cogging torque, so put the minimum higher than the force it takes to overcome whatever forces you're working against(wind, hills, cogging torque, etc.).
Anyways, report back any features you want! Suggestions for improvements! Bugs! Etc.! I'm making this for the community, so feel free to help improve it.
And, also, a manual/help guide will be eventually developed that describes each variable in detail(including how to determine it). On a side note, "RPM" stands for the motor's RPM in the graph. I should add that...
EbikeCalc0.12.zip
This is for other computer systems the .exe above won't work on. Make sure to extract it so that the folder structure is preserved.
(1.68 MiB) Downloaded 169 times
swbluto
Postby michaelplogue » Wed Nov 05, 2008 8:56 pm
Very groovy!
How difficult would it be to include a horsepower value? :wink:
michaelplogue
Postby swbluto » Thu Nov 06, 2008 6:31 pm
It shouldn't be difficult. :mrgreen:
I've figured how to align the different variables and each variable now has its very own special color and axis, so comparing is made easy! I'm also thinking about undertaking some rigorous algebraic analysis to figure out accurate estimates for the hub motor's specs from ebikes.ca's charts so the efficiency and heat generation can be calculated accurately. So that may get corrected in the next release!(Possibly by tomorrow.)
swbluto
Postby Mathurin » Sun Nov 09, 2008 3:42 am
swbluto wrote:Also, 26.3 cm is pretty small for a wheel diameter... :wink:
That's the default value. I still cringe at diameter used for this purpose, would prefer rollout in mm like on bike computers.
Also if you're going to include acceleration, a speed/time at 30m would be a nice touch for urban cyclists.
Edit:
Found a pretty nice calculator online, it's for scooters but is otherwise pretty nice. Very complete instructions, needs a tubful of polish tho.
http://trottelec.ifrance.com/performa.html
Mathurin
Re: New E-Bike/E-vehicle calculator - Beta testing/Debug
Postby swbluto » Fri Nov 14, 2008 7:43 pm
Here's the newest release. The zip file is below and the self-extracting archive that avoids common installation problems can be found here. The zip file is for any system whereas the self-extracting archive is for Windows. The zip file should be unzipped in its entirety so the folder structure is preserved as the program depends on the correct folder structure.
I've added the rudimentary acceleration; Some axes are aligned; Help files have been created with the corresponding menu items; about menu item added; The ability to save input and open input files; and other fixes such as the hub motors. The hub motors aren't perfect but they seem more accurate than before and they still seem to accurately predict my speed.
I'm planning another type of graphing so that you can see your acceleration, speed and distance over time. So if you wanted to see your speed at 30 m, you'd just find where the distance curve is at 30 meters, and you can see your time, velocity and acceleration at 30 meters. This would seem to be a "computationally involved" problem so there's a lot of thinking needed to reduce the total amount of computation(i.e., make it graph quickly), so this might take some time to figure out.
That calculator looks nice but I don't understand French so it seems I can't use it.
A problem with adding the roll-out is that I don't know how to include more than two options along with making the interface "look nice". It'd be possible to use a drop-down menu to select the preferred way of measuring it, but that would seem to uglify and make it look unbalanced.
ebike_0dot13.zip
The folder structure must be preserved for correct operation.
(1.67 MiB) Downloaded 127 times
swbluto
Postby swbluto » Sun Nov 16, 2008 12:47 am
OMG! I fixed the hub motors. Now the graphs are >98-99% true to ebike.ca's graphs for at least the 40x series(And the predictions should be equally accurate). It appears the formula for calculating winding resistance from the winding temperature was entered in wrongly, but now it's fixed.
Anyways, I'm going to add the graphing code and then release all these fixes and updates in the next release. Might be some time next week.
swbluto
Postby Siress » Tue Dec 16, 2008 10:18 pm
So... :?
Siress
Postby swbluto » Wed Dec 17, 2008 12:07 pm
So it's been some time! Shortly after my last post, I received my electric scooter and was all involved in upgrading that. I also received my acceptance letter to UW, which then initiated blazing a path of finding an apartment in a city on the other side of the state practically entirely online and other academic planning, so I've been fairly busy. I recently completed much of what that entailed (including scoring a sweet 1/2 bedroom apartment for $700/month with everything included! That might not sound like such a good deal but it is in Seattle's rental market!) just recently and I'm waiting until January to buy and install a proper outrunner controller and getting it working but I'm thinking of completing the throttle-system and water-proofing parts before hand just to get it out of the way.
As far as the software, I've corrected the temperature formulas which seems to increased the accuracy of the charts to practically replicating ebikes.ca's simulator for the 40x series motor, and "pretty darn close" for others(I haven't checked the other motors and corrected whatever but it shouldn't be off by a significantly noticeable amount). Also, now a transient simulation graph for acceleration, velocity and distance has been created so it can predict how fast you'll go, how far you are, and how quickly you'll accelerate from a stand-still and it shows it over time. And... that's all I can remember at the moment.
WARNING:
This program does not take into account drive train efficiency, so if you're using a drive train system to rotate the wheel (i.e., with an R/C motor, Etek or other things that aren't hub motors), make sure to take off 5-10%(or add 5-10%) of the relevant values to get a "realistic idea". Example, if you have a two stage drive system, imagine taking off about 5-10% of the top speed, so a top speed of 33 mph would be about 30-31. The acceleration time of 50% of top speed would be somewhere around 10% more so 10 seconds would become something like 11 seconds.
For Windows, a self-extracting .exe has been created to ease the set-up process: http://www.mediafire.com/download.php?lgj4zy2mz44
And for any system with the ability to unzip .zip files, the main zip folder(Make sure to unzip the entire zip file to preserve the folder structure which the program needs to operate correctly) is below.
ebike_0dot15.zip
E-bike simulator version .15
(1.85 MiB) Downloaded 1006 times
swbluto
Postby Grinhill » Sat Jan 24, 2009 11:32 pm
Just got the program to run on my machine.
I initially had a problem because of a Nokia PC Suite for phone, which stole the file association for .jar files (doubleclicking on the calculator file started the Nokia program).
I couldn't get the file association back to what it should have been, but then I found a program called "jarfix" from softpedia.com which worked a treat.
1995 Giant Hybrid - Zeta2 with 12V 7AH SLA - removed after one year.
2006 Converted Giant to Geared Brushless Rear Hub with 24V 17AH SLA - bike stolen 2007.
2008 Hardtail MTB Disc Brake - lightweight RC/LiPo system.
Grinhill's Medium-power RC-Motor Hardtail build
The Grinhill Mk2 RC-motor drive
Grinhill III - "Supercommuter" featuring Recumpence RC drive
Grinhill
Postby wanders » Sun Jan 25, 2009 3:48 pm
swbluto:
Excellent work - congratulations.
I've been contemplating a similar tool (and didn't realize that you had already built one). I had done some similar modeling in Excel for vehicle dynamics, and had modeled similar parameters to your program.
HOWEVER, what I believe is needed is a way to take a ride (defined as a set of length segments, each segment with a particular grade and a target velocity) and use a tool such as yours to estimate overall battery consumption. You can now pretty trivially use http://www.mapmyride.com/ to get excellent grade profiles of any route. If we could take a table of such data and use your calculator to estimate overall ride energy consumption, it would be great - and I wouldn't have to write it myself in Javascript :)
Willie
wanders
Postby methods » Thu Jan 29, 2009 8:35 pm
[quote="swbluto"][/quote]
Dude, that software is bad izzl!
No troubles. I just unpacked and the jar file ran fine
I dialed in my specifics and attempted to maximize my wh/mile.
Your calculation is very close to what I have been seeing on the CA.
Nice work :!:
I plan to spend many insomniac hours playing with this program.
-methods
The things I have for sale
Notable failures:
88V 9Ah 100A 5305 - Dead - 420 degree windings
88V 9Ah 100A Cyclone - Dead - gears exploded, motor is fine
88V 15Ah No current limit 9x7 9C + 9x7 9C 2WD Electra Cruiser - Insane traction issues- decommissioned
88V 15Ah 120A 5305 - Dead - Spun stator on axle
methods
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: MSN [Bot] and 2 guests
