nemo wrote:fechter wrote:That's a 16v zener. Its the reference for the voltage regulator.
Thank You, that explains a failure on 36V and not on 24V then!
A 5v reg. was burned and also some caps.!
fechter wrote:I measured 16v across the one in my controller when it was powered up. You lose about a volt in the transistor.
Perhaps they figured out that was too high at some point and changed the value of it.
The feed to the hall sensors is through a resistor, so the actual voltage at the sensors drops when they are connected. Still, if the supplied voltage is really close to the failure point of the sensors, that could explain a lot of failures.
If the zener goes open or the transistor shorts, it would be real ugly for the rest of the controller.
Connect the Battery Pack to the Controller
22. Connect the battery pack to the controller. If your keyswitch is on when you make the connection, you will hear a “popâ€￾ and maybe see a spark. This is normal behavior. It will not hurt you or the system.
rf wrote:The Crystalyte Home Assemble Guide says the following:Connect the Battery Pack to the Controller
This is dumb. As someone mentioned on another site the Crystalyte controller needs an inductor added between it and the batteries.
I use a Radio Shack `Snap-Together Toroid Choke' (part #273-104, $8.39 for two) that I happened to have lying around. I wrapped it with 12 turns of #12 wire and added it inline with one of my battery cables. Much reduces the sparks, pops and eroded connectors and switches.
http://tinyurl.com/285dsd
Richard
fechter wrote:The pre-charging resistor is the best, but I hadn't thought one of those snap on ferrite chokes would be that effective. Everything helps.
The Crystalyte controller has a capacitor which appears as a large initial load when the pack is connected or turned on. This can blow a fuse or cause the BMS to open. My solution was to add a small inductance in series with the controller. This inductor does not waste much power in actual use, since it never seems to warm up. Inductor was ten turns of #14 wire around a ferrite toroid Mcmaster-Carr #8495K57.
Cyclemotor Engineer
http://www.neodymics.com
fechter wrote:There's a capacitor on the board that controls the ramp up. Stock is 10uf. If you replace it with a smaller one, like 1 uf, it will ramp up much quicker.
It might work to just remove it completely.
fechter wrote:Combined with the typical zero offset on the throttle, I think you get the delay effect. If the throttle voltage is 1v, but the controller doesn't start making any output until 1.4v, you get a delay while the throttle ramps up to 1.4v. This is oversimplified, but I think that's essentially what's going on.
If you install the trimmer on the throttle so you just barely move the throttle and the motor goes, you'll see the delay is much shorter.
rf wrote:So the intent was to turn on some power immediately but it's misadjusted?
Optimal would seem to be zero delay. Which is especially noticeable with light trail riding.
Richard
fechter wrote:rf wrote:So the intent was to turn on some power immediately but it's misadjusted?
Richard
Any delay is really annoying to me. I don't really have any noticeable delay on mine. Try the trimmer.
Users browsing this forum: its_me_jason and 11 guests
