Doctorbass wrote:I discussed with some electrical maintenance senior at my job and they said the use this configuration in star to delta their large 3phases motors and then they start them to require less current. the gain ratio for speed is 73% if i remember?
Tiberius wrote:Also, AFAIUI, these changes are not the same as mechanical gearing after the motor. You can't make the motor more efficient at low speed by doing this, all you can do is push it to higher speed.
kZs0lt wrote:Tiberius wrote:Also, AFAIUI, these changes are not the same as mechanical gearing after the motor. You can't make the motor more efficient at low speed by doing this, all you can do is push it to higher speed.
Does this mean that the efficiency is the same whether star or delta, making the switch absolutely useless, unless you you want to change rim diameter or battery pack voltage? That would mean that you can stick to 5302 or delta for more speed, and switching to higher windig or star using SAME POWER(current x voltage at full throttle) would not give you more torque or better efficiency at low speed? Or at least the change would be so small that you couldn't feel it?
Those using 406/4011 or other dual winding hubs, what are your real experience?
Doctorbass wrote:Tiberius wrote:Also, AFAIUI, these changes are not the same as mechanical gearing after the motor. You can't make the motor more efficient at low speed by doing this, all you can do is push it to higher speed.kZs0lt wrote:Does this mean that the efficiency is the same whether star or delta, making the switch absolutely useless, unless you you want to change rim diameter or battery pack voltage? That would mean that you can stick to 5302 or delta for more speed, and switching to higher windig or star using SAME POWER(current x voltage at full throttle) would not give you more torque or better efficiency at low speed? Or at least the change would be so small that you couldn't feel it?
Doctorbass wrote:... for example with a 5202, to get 100A that will be difficult to reach over 60-65V.. at full throttle so it's 6500W max that you can put in
In the popposite a 5305 will need higher voltage to get 100A and will need around 90-100V at full throttle.. Thats 9000-10000W Max so this is a fact that the 5305 with longer winding allow more power than a 5302.
John in CR wrote:Doctorbass wrote:... for example with a 5202, to get 100A that will be difficult to reach over 60-65V.. at full throttle so it's 6500W max that you can put in
I've read through this thread a number of times, but I keep coming back to the thought that the 5202 is the more powerful motor. To me its shorter windings and effectively greater wire gauge from more parallel strands is capable of handling greater current flow due to the lower resistance. The part I really don't understand is why the 5202 would be limited to 60-65V, while 90-100V is possible with the 5305. Why would the voltage limits be different? I thought these BLDC motors didn't really have voltage limits other than structural limitations of the maximum rpms they can withstand. That would mean the one that can handle the most current is the most powerful.
John
John in CR wrote:ZapPat,
Won't the one with the shorter thicker windings be able to handle more current? Then assuming you're running the same voltage, then the one that can handle more amperage is capable of producing more power. It won't have the same low end torque without wasting batteries, but it will push through more wind, up at the top end, won't it?
John
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
John in CR wrote:Doc,
I think I understand, but you qualified it all with a current limit on the controller. What I'm looking for is, "Which is capable of more power?", assuming current and voltage aren't artificially limited by the controller or batteries.
Methods,
I think the best answer is to first minimize the creation of heat. I'm going to try some 2 motor alignments that aren't full time 2wd. Doc is trying the switchable windings. There's been talk by a few of cooling systems. I'm sure many are working on a better motor, but they'll be expensive and probably slow to become available. What else can we do without sacrificing performance?...Maybe a braking loaded spring or mechanical device to help bear some of the load of takeoffs...
John
Users browsing this forum: chroot, launchpad, robbie, tony67 and 11 guests
