ixandstones
Hello all
I'm having some configuration issues with my CA.
I have a large 60v Luna Battery, a 60 Amp Lyen Controller for the LR Big Block and the Big block enigne on the luna cargo. I have two main issues:
1) Pedal assist not working
I have set up a custome magnet setup on the chain ring for the pedal assist sensor. As the magnets go in front of the detector, both the P and D arrows on the CA change direction. The LED on sensor lights up. However the CA does not pick up a cedence in screen 3 and the assist never kicks in. Or randomly kicks in for a very short burst and cuts off. I dont know quite how to handle this.
My PAS Settings are as follows:
5 pole
5V = Rev
2 Wire
Start Thresh= 35 RPM (went all the way down to 10 with this, did not do a thing)
Stop Thresh= 58 RPM
Auto PAS
500 Watts
99 mph limit
2) Power adjustment (throttle ramping and surging)
I lowered the upramp to .51 V/sec since the original power from the throttle was too much. I honestly don't see much of a difference but now have this weird oscillating power when at full thottle. THe throttle power oscillates up and down for some reason.
Throttle and power setups:
Throttle Output:
Voltage
Max: 3.65V
Min: 1V
Rampu up rate 0.51V/sec
Ramp Down Rate 4 V/sec
Fast Up Ramp: 4.00 V/sec
Fast Ramp Thresh: 3A
Throt out Ebrake: 0 V
Thottle In:
Min In: .95V
Max I: 4.10 V
Fault: 4.31 V
Mode: Pass Thru
Auto Cruise: Off
Power Limit:
Current: 40A
Power: 4000 W
Amps Feedback Gain: 150
Power Feedback Gain 15
Any help would be greatly appreciated.
Thanks
5 pole
5V = Rev
2 Wire
Stop Thresh= 58 RPM
Auto PAS
500 Watts
99 mph limit
Throttle Output:
Voltage
Max: 3.65V
Min: 1V
Thottle In:
Min In: .95V
Max I: 4.10 V
Fault: 4.31 V
Mode: Pass Thru
Auto Cruise: Off
Power Limit:
Current: 40A
Power: 4000 W
Thanks
