AS the Subject heading said, the computer screen on the Cycle Analyst 3 shows a blinking throttle and the throttle is not engaging the motor? The blinking throttle is indicating a Wide Open Throttle.
If I change the screen to the "Diagnostic Screen" and push the throttle I can see it at the starting point of 0.86 volts and when I press the throttle WOT volts go up to 4.26, so it looks like it works. But if I power down the Phase Runner controller, then power back up and plug in the throttle it works fine and the blinking goes away and power is set to the motor?
I am guessing it is some setting that got messed up when I was setting speed limits and such.
Any suggestions how to fix this?
