eaglegamma
100 µW
- Joined
- Sep 26, 2017
- Messages
- 9
Hi,
After recently buying a used Wilderness Energy Bike Electrified kit, I set it up and got it working briefly, but now it's not working. I'm using new batteries (36V, 9AH, SLA). I've tested them with a multimeter and they are fine. (I've tested the wiring up to the controller, and it all checks out at around 38V. From the controller to the hub motor I don't see how exactly to check the voltage.) I've charged them up and tried running the motor off AC, still not working. The LEDs on the throttle light up, showing power and full battery. Yet when I push down on the throttle it doesn't rotate the motor.
For a little while I had the motor running, but when I adjusted the batteries to strap them together and onto the rack, after reconnecting I've had trouble getting the motor to run. I've tried substituting practically all the parts with the same parts from another kit of the same model, with similar results. I've tried disconnecting and reconnecting all the wires, and it's still not running.
Can you suggest what I should do next, or what could be the problem?
Would any additional info help?
Thank you!
Thank you!
