whereswally606
So I have a Norco team Race DH 2004 ish vintage, this is fitted with two Dr Bass torque plates inside the dropouts, the dropout width was 150mm. My Largish hub from devi-motion fortunately fits snuggly being a 135mm dropout with hub. I had it re-laced into a 26" rim from a 28" and the chap who did it made it radially spoked and with no dishing. This has worked well for me for a few years as I never needed to use the low gears due to lack of serious hills and presence of a large motor to assist.
The current situation is that for allowing suspension compression I have a cheap shimano derailleur with a fixed small section of cable keeping the jockey wheels aligned with gear 6. That is I am using the highest gear ratio all the time.
My issue is that because of the spacing effect of putting the thick torque plate on the inside of the dropouts I have reduced the ability of the derailleur to reach the lowest 2 or 3 gears on the freewheel.
My thoughts are that I need to make a spacer to take the horizontal displacement back to where the derailleur could reach those lowest gears. However I am not sure whether there is an easier solution I am missing. I don't want to redo the wheel dishing or remove the torque plates, the wheel rim is dead nuts central between the swing arms.
I have only the largest 44t ring at the pedals so I could do a 3 ring set there but I don't really want 18 gears id be happy with the 6 at the back. plus you get a bigger effect at the back than the front where shifting is concerned.
Any Ideas??
Any Ideas??
