Sabvoton On A Bomber
st35326
Post by st35326 » Oct 23, 2017 9:22 pm
At the advice of many on here I picked up a Sabvoton SVMC72150. Came with no instructions, anybody know how this should be hooked up on a Crystalyte 5403?
This is the wiring off of the motor
st35326
Re: Sabvoton On A Bomber
Post by st35326 » Oct 23, 2017 9:23 pm
Here's the wiring
st35326
Post by st35326 » Oct 23, 2017 9:26 pm
Im assuming the yellow, green and blue on the controller correspond to my phase wires.Not sure about the halls though.
amberwolf
Post by amberwolf » Oct 23, 2017 9:55 pm
Like any other controller and motor, unless the controller has a self-learning feature, you'll have to experimentally determine the wiring order
https://endless-sphere.com/forums/viewt ... =16&t=3484
https://endless-sphere.com/forums/viewt ... =1&t=32455
You can check the various Sabvoton threads for info about them; not all the threads in the list linked below will be relevant. Probably the one in the for sale section would have the most info?
https://endless-sphere.com/forums/searc ... mit=Search
st35326
Post by st35326 » Oct 23, 2017 10:02 pm
amberwolf wrote:Like any other controller and motor, unless the controller has a self-learning feature, you'll have to experimentally determine the wiring order
Ok thanks, I believe it's supposed to self detect the halls? I could be wrong though.
amberwolf
Post by amberwolf » Oct 23, 2017 10:18 pm
That would be self-learn; if it has the feature you'd want to look up how to activate it. (could be a jumper wire, could be programming via computer, etc).
st35326
Post by st35326 » Oct 24, 2017 12:40 am
amberwolf wrote:That would be self-learn; if it has the feature you'd want to look up how to activate it. (could be a jumper wire, could be programming via computer, etc).
Right on, I believe this can be accomplished through the programming. I just don't want to burn anything up if I hook it up the wrong way. :oops:
The Raine build seem to be coming along nicely.
FL bomber
Post by FL bomber » Dec 05, 2017 1:39 pm
How does the controller look on the bike? It looks wider than original stock bomber controller. Does the Cav 3 work with sabvoton?
