Daymak/yuyang 30amp controller Bluetooth problem
Sidotian
Post by Sidotian » Nov 18, 2017 2:14 am
Ok so IV had this problem for just about a year now when useing my yuyang king controller bought from Luna cycles it will not let me into nor change the settings, IV tryed 12s and 18s and I can't seem to fix the problem. The temp/amp/voltage/mph are still functioning however. When I plug a battery under the lvc which is set to 38v IIRC because I can't get to the setting to see at actually says low voltage not just a icon. IV tryed the daymak app also it works but the settings won't work. I really do not want to buy another controller just to access setting when this one drives fine. If anyone has had this experience or could offer advice on how to fix the problems that would be greatly appreciated.
Screen shot of error symbol
x.l.r.8
Re: Daymak/yuyang 30amp controller Bluetooth problem
Post by x.l.r.8 » Nov 20, 2017 9:38 pm
Where are you setting up the low threshold from?
Intelligence is distributed nearly evenly, with only the occasional concentration in one person. The total quantity of Intelligence is a constant: as more people come into being, fewer and fewer get a sufficient amount for themselves.
Some say this has already reached homeopathic levels.
Sidotian
Post by Sidotian » Dec 27, 2017 1:32 am
The low voltage cut off? That's set for 38v if I remember correctly but I have never actually ran a 12s pack that low. IV also tryed 18s and just to test it out I hooked up a single 6s pack and it actually says low voltage but this issue isn't saying anything
Last bumped by Sidotian on Dec 27, 2017 1:32 am.
