Springer55
10 µW
- Joined
- Nov 23, 2017
- Messages
- 5
My ebike won't run. Battery indicator on display shows battery empty. Battery volts on display show 41v.
I have a 36v dolphin battery, kt-lcd3 display and a kt-36s controller anx a 350w mxus hub motor. Battery voltage on display shows 41v. Battery voltage with a meter shows 41v. The little battery indicator at the top of the display shows empty.i checked to make sure all my connectors were tight.
Put bike on my rack. Motor will run slowly at about 2mph and chatters. No visual problems inside controller.
This showed up after I finished charging my battery.
Could this be a bms problem, or something else?
I appreciate any suggestions.
