Possible to enable regen on a controller from Mxus?
redmouse
Post by redmouse » Dec 26, 2017 4:19 am
Hi everyone, I got myself this controller
https://imgur.com/a/CCCWk
I use it together with 14S7P battery and 9C hubmotor.
I would really like to have regen function, but either it doesn't have it at all, or it is hidden or disabled.
When I spin the motor to top speed and short the black and white twin cables, it doesn't do anything except for disabling the throttle.
Is there a chace regen can be enabled somehow? If yes, I can take it apart and post pictures.
Maybe I need to do something with that display connector?
I also found this picture https://imgur.com/a/Pqrzd in Infineon controller .doc from here https://endless-sphere.com/forums/viewt ... =2&t=19446
Could it be that my controller is rebranded Infineon? And I just need to do this to enable regen?
redmouse
Re: Possible to enable regen on a controller from Mxus?
Post by redmouse » Dec 27, 2017 3:59 am
So I opened it, and unfurtunately it's not an infineon :(
https://imgur.com/a/wT4kc
I managed to identify "high brake" pin, but it doesn't do anyhing (I tried connecting it to GND and also to battery +, but there is nonchange in motor behavior, and the brake cutoffs still only dible the throttle, nothing more.
Should I give up and look for other controller?
Would you recommend a suitable one? My battery is 14s (aka 52V), and can provide 30A.
wesnewell
Post by wesnewell » Dec 27, 2017 5:56 pm
Regen won't work on a lot of controllers if the LVC is too low for the battery connected. I had to change the LVC on my 72V controller when I went over 78V of battery. That nay or may not be the problem you're having.
