ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL stator
Re: ELECTRIC TRANSMISSION Video DELTA / WYE With 9 continent
Postby paultrafalgar » Thu Mar 19, 2009 4:08 am
Gui, have you a link for the Pheobus rally? Can't find one on Google.
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby GUI13 » Thu Mar 19, 2009 4:42 am
ouuuups ! :oops: rally phebus http://rallyesolaire.eu/
GUI13
Postby paultrafalgar » Thu Mar 19, 2009 5:36 am
Thanks, Gui, and here's what Google translated that into:
A solar rally, why?
The sun is tested constantly by satellites and observatoiresterrestres to better understand its operation and its influence on our climate.
The earth is a solar collector in space and our daily life depends on it. People naturally use solar energy for hundreds of thousands of years. Now came the time when they rediscovered as a source of clean, renewable energy.
For satellites and spacecraft, this energy is immediately seen as the most cost-effective. The will of the founding organizers of the rally, 'ENSEEIHT Phébus Ariège, the CNRS and the Cité de l'espace, is to be the core issues related to environmental quality, which led them to create this draft Solar Rally in 2000.
The technology required to make a solar vehicle are often researched and developments which the space is a precursor.
By organizing this European Solar Rally, we want to offer the public a better understanding of the challenges and enormous potential energy that represents for us the nearest star to Earth, the Sun!
From 28 to 1 June 2009
So you see your Engish is better than Google's translation of French! :D
paultrafalgar
Postby fechter » Thu Mar 19, 2009 8:45 am
Nice bike!
Where do you put the batteries?
fechter
Postby GUI13 » Thu Mar 19, 2009 8:49 am
in my backpack !
GUI13
Postby karma » Thu Mar 19, 2009 9:46 am
hay it works nice work gui13. i never got around to trying it. now that i see the results, i think its worth the extra work. :wink:
cheers
karma
Postby solarbbq2003 » Thu Mar 19, 2009 12:32 pm
gui just wondering if the windings are all in parallel like inpic below, or maybe some in series? could change motor rpm etc by changing how the coils are connected also
fp parallsmall.jpg (60.44 KiB) Viewed 2684 times
solarbbq2003
Postby Bouladou » Thu Mar 19, 2009 4:22 pm
Bonjour à tous.
Je vous lis souvent grâce à un traducteur car je suis nul en Anglais !
Je met un lien pour Doctorbass sur une discussion ou il y a des renseignements sur les moteurs 9 Continent.
http://cyclurba.fr/forum/51960/differen ... &pageprec=
Je suis très intéressé par : ELECTRIC TRANSMISSION Video DELTA / WYE With 9 continent mais je n’y comprend pas grand choses. Je vais voir avec Gui13 et d’autres s’ils peuvent m’expliquer le principe ?
Salutations amicales
Hello to all.
I often read through a translator because I am no one in English!
I put a link to a discussion on Doctorbass or there is information on engines Continent 9.
I am very interested in: ELECTRIC TRANSMISSION Video DELTA / WYE With 9 continent, but I did not understand much. I will do with Gui13 and others if they can explain the principle?
Kind regards
Bouladou
Postby Doctorbass » Thu Mar 19, 2009 4:27 pm
solarbbq2003 wrote:gui just wondering if the windings are all in parallel like inpic below, or maybe some in series? could change motor rpm etc by changing how the coils are connected also
The attachment fp parallsmall.jpg is no longer available
I also had this idea but the major problem is the qty of wires that goes out of the motor that is too high!! 10 to 12 wires!! instead of 6 like the delta WYE
Also the ratio would be 2 instead of 1.73 for the delta wye. so the current demand would be twice :shock:
See the drawing i did few month ago:
Doc
(38.79 KiB) Downloaded 394 times
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby tostino » Thu Mar 19, 2009 8:32 pm
How possible/easy would this be to do with a Bafang motor? Does it have enough room to have all the wires going out the side of the case?
tostino
Postby wasp » Tue Mar 24, 2009 1:00 am
could i bypass the extra wires and switch by just wiring delta?
wasp
Postby Doctorbass » Tue Mar 24, 2009 9:14 am
wasp wrote:could i bypass the extra wires and switch by just wiring delta?
yes.
In delta mode the current will increase to 1.73x so the controller may heat a bit more :wink: pay attention to that!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby wasp » Tue Mar 24, 2009 4:31 pm
yes.
Doc
thx Doc if i do overheat i'll step up to infinion and limit amps with ca
wasp
Postby karma » Wed Mar 25, 2009 5:37 pm
ill say one thing running the extra phase wires was a pain in the arse but i pulled it off :mrgreen:
karma
Postby Doctorbass » Wed Mar 25, 2009 6:25 pm
Great!!.. what is the wire gauge you used? (to have 6 phase wire out of this bolt axel?
Did you tried the delta mode?
Can you take more photo (close up to the phase wire input and output from the axel + closeup on the winding ire soldered?
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby wasp » Wed Mar 25, 2009 7:25 pm
nice karma
any video comlng
wasp
Postby karma » Wed Mar 25, 2009 8:52 pm
ya just did a test im uploading them now. i will say one thing. when you see it in person the speeds insane :twisted:
karma
Postby wasp » Wed Mar 25, 2009 8:57 pm
can't wait...36v or 48v
wasp
Postby karma » Wed Mar 25, 2009 9:04 pm
70v and i found out my wheel needs truing talk about out of ballance. you will see in the vids.
cheers
karma
Postby Doctorbass » Wed Mar 25, 2009 10:07 pm
Hey Karma... Where is your delta/wye golden motor vid 4 ?? :wink:
Interesting video exemple about the Delta/WYE.. Thanks
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby karma » Wed Mar 25, 2009 10:36 pm
there taking forever to load im sure you will like this one :twisted:
http://www.youtube.com/watch?v=pJFp8Ao4XPs
karma
Postby Almasi » Wed Mar 25, 2009 10:51 pm
karma wrote:70v and i found out my wheel needs truing talk about out of ballance. you will see in the vids.
cheers
I'm curious if it's not more out of balance....would the valve weight unbalance a wheel? (I would be curious to try to balance my wheel at 80KM/H)
This vibration is doing something to efficiency for sure...
Robin
Almasi
Postby Doctorbass » Wed Mar 25, 2009 11:06 pm
Ah haaa!!.. that's perfect!!
Now who will try that first on the road :twisted:
Gui... YOU... Me... Almassi?
(please be carefull with this Delta mode... The parasitic current stay in the winding loop and is more subject to overload mosfets withg some noise..
So let's try step by step first at low speed... I dont want to someone blow his controller because of that... and having a controller mosfet short at 60kmh or + is,,,,, VERY BAD.. it can freeze the wheel like you can not imagine!.. like a short circuit direct on the phase wire.. a 100% regen in a second!!!
So let's not blow this great idea and let's be carefull to preserve this great idea intact...
why not start with few video with 10kmh.. then 20kmh.. etc....
Who know.. up to 90-100kmh could be fun if nothing blow... :twisted: ...but only as fast as a 5305 can do 8)
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby wasp » Thu Mar 26, 2009 12:24 am
looked fast karma's bike
reminds me of the kick a 2 stroke does in the powerband
delta=powerband....hang on delta's bout to kick in lol...
wasp
Postby karma » Thu Mar 26, 2009 9:50 am
hehe ya i did a on road test just in delta. this setup will only work good if it kickes in at maximum rpm. so im going with doctorbase's relay idea. would be nice to have a turbo button :D
karma
Next
Return to E-Bike Technical
Who is online
Users browsing this forum: Google [Bot], scphantm and 16 guests
