ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL stator
Re: ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL st
Postby Arlo1 » Mon Jul 05, 2010 10:54 am
We need to see results already! Doc you should be just about ready to test yours? I am afraid luke might be right so if there is gains is maybe very small almost to the point you cant feel it. Some one actualy ride this already. If I wasnt preping for a car show I would be trying this my self.
Arlo1
Postby liveforphysics » Mon Jul 05, 2010 11:01 am
Doctorbass wrote:
btw, i'm correcting all my previously understanding of Phase current and current multiplication. LFP and Justin are now convincing me to correctly better play with the dark side of electrons and copper!
Doc
This is outstanding news Doc! :) You're going to have the insight now to make better choices and matching up battery with motor with controller than ever before now, and the results are going to kick ass harder than ever before! :)
The road of excess leads to the palace of wisdom
Experience is a hard teacher. First comes the test, then the lesson.
Best Lithium battery testing highlight video EVER!!!! :)
http://www.youtube.com/watch?v=dree0rTr1HM
liveforphysics
Postby Doctorbass » Mon Jul 05, 2010 11:05 am
My point on that is that if i would only go with a 5303 and try offroad with alot of hard accelerations and stop ( worst conditions), then the controller would overheat and probably blow.
By using the motor in 5306 mode the controller will less overheat and i will get the same torque or a bit more i think.
5306 will be most for the offroad ( it's a DH ebike after all).. and the 5303 will offer me a bit more speed... :twisted: 5303 100V 24" wheel with 3.0" tire
The tire and rim are the exact same as the stealth bomber ( i want to try that setup style for fun)...
I remember that the controller used with my 5302 at 172A burst become VERY HOT!! and that the same conditions with my 5305 , make the controller still cold or a bit warm... A HUGE DIFFERENCE!!
Doc
________________________
ULTRAFAST DH ebike:
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec !! X5 5303 on 24"
-18 fets controller
-Peak power 18350W (23hp)
-24s 3p lipo
TORQUE SETUP:
-Succeded to haul a 19200 pounds schoolbus!!!
-202km range no pedal -
- 0-50km/h in 4sec!!
-100.8V 23Ah BATTERY made of 432x 18650 cell from Lithium Makita 3Ah 18V LXT -Team Konion™ Member
-Top speed 62km/h Torque 230lbs trust !!
Doctorbass
1.21 GW
1.21 GW
Postby Doctorbass » Mon Jul 05, 2010 11:29 am
liveforphysics wrote:
Doc
Hey Luke, What i can say and share with the E-S now about motor winding choice and controller limit is this:
Setup no 1:
Speed record Killabicycle project ( summer 2009)
5302 on 20" wheel
18 fets controller 4110 that burst at 172A fluke shunt calibrated with kelvin 4 wire method
100A battery current and 160A phase current
Block time : 1
100V battery
Acceleration: 0-70 kmh in 5 sec
-Result after 4 or 6 accelerations to 70 kmh for test: The controller get very HOT !!!! but not blow
Setup no 2:
Mongoose with new 18 fets controller ( summer 2010)
5305 on 20" wheel
18 fets controller 4110 that burst at 221A fluke shunt calibrated with kelvin 4 wire method
100A battery current and 250A phase current ( 2.5 ratio)
Block time : 1
100V battery
Acceleration 0-60 kmh in 5 sec
-Result after 4 or 6 accelerations to 70 kmh : The controller still cold or warm.. no real feel of any danger or heat on the case
my conclusion: in very close conditions, the 5302 offer similar performances as the 5305 but the 5302 make the controller become very HOT !!! and the 5305 dont.
My understanding is that higer turn winding motor are better but if you want to have both torque and speed and not overheat something.. we must use dual winding setup like relay switched stator
Doc
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby liveforphysics » Mon Jul 05, 2010 11:38 am
Doctorbass wrote:I remember that the controller used with my 5302 at 172A burst become VERY HOT!! and that the same conditions with my 5305 , make the controller still cold or a bit warm...
Doc
I bet! That controller running the 5302 was pumping out 2.5times the current the 5305 controller would be doing when starting from a stop if they are both drawing in 172amps at the battery! Easily could have been in the >600phase-amp range starting from a stop.
Like I said, the series-parallel switching plan you've got has the ability to take away half or more than half the heat load on the motor for the first 0-20mph of acceleration or so, that could be pretty handy. :) But then the question becomes, is it easier to mechanically switch motor windings with relays inside the motor, or just make a controller FET stage capable of more currents (like maybe using some TO-264 package FETs on a custom heatsink).
liveforphysics
Postby andreym » Mon Jul 05, 2010 1:40 pm
Doc
In that case i believe the controller should be INSIDE the motor because just imagine the wires thickness to allow say 500-1000amps through phase wires? 1awg? 0awg?
and with controller located inside (at least power fets) you could easily power this with say 20kw at 100v and 200amps using 10-8awg)
Rear 9C 9x7 16S2P Turnigy LiPo
Lyen 18Fet controller 120% speed settings, 68kmph max speed.
Hayes 9 front brakes, modified brake lever for rear e-brakes.
Merida 300TFS frame
Fox F100RL 100mm front fork
andreym
Postby Doctorbass » Mon Jul 05, 2010 4:47 pm
Doc
Not exactly .. Like Luke explained before, The phase current is not 100% time on every cycle of the AC .. it's duty cycle..
otherwise with 600A at 80V that would be 48000W and the battery dont do that... continuous battery current is transformed into Phase current that is just pulsated partially oin time on each cycle of the high frequency that the controlelr send into the motor winding...
Doc
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby Doctorbass » Mon Jul 05, 2010 4:50 pm
Doc
or... maybe just make a better mosfet dissipation... :wink: ON my present 18 fets controller i am using thick copper bar instead of aluminum and also i use kaptin tape instead of that grey rubber stuff as mosfet insulator... I guess it already help ALOT !!
but guess what.. .the doubled phase wire from the motor to the connector ( dual 12 gauge for all phase ) and ( all in 10 AWG for the controlelr side that also become REALLY HOTT!)
That 5302 is also a PURE current monster eater!
Doc
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby John in CR » Mon Jul 05, 2010 8:40 pm
Doctorbass wrote:That 5302 is also a PURE current monster eater!
Doc
The 5302 is a much better motor as far as I'm concerned. Look, it out performed the other one despite being handicapped by a lower current limit. Imagine what it would have done with a controller manly enough to feed it the current it wanted. The results wouldn't have been even close. It wanted and could handle double the current, but it got less current. As long as you're not bumping up against saturation limits of the stator it's capable of 0-70 in under 3 seconds with double the current.
John
John in CR
Postby steveo » Mon Jul 19, 2010 6:41 pm
Doc
John
5303 all the way!!!... Dual winding x5306-x5303 ... hard to beat!
http://www.youtube.com/user/trdfreak03
Infinity Titan Bike/24 mosfet irfb4110 @ 200 amps - 20hp+/24" x5306 New Gen Crystalite/24s 4p A123 Battery/45k/h top speed/ torque demond
New Build Supercycle/18 mosfet irfb4110 @ 175 amps/x5303 20"/ 20s 4p a123/
you've tried the rest .. now try the best!
24 mosfet/18 mosfet/12 mosfet 100v IRFB 4110 controllers for sale. Pm if interested
steveo
Postby Doctorbass » Mon Jul 19, 2010 7:47 pm
steveo wrote:
Doc
John
Did you tried yours??
:shock:
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby steveo » Tue Jul 20, 2010 12:10 am
i came close ... however i could not run the motor because i could not get everything to fit in the case... your pcb is what i want !!!!.. doc put me on the list for those pcbs .. i'll be interested in a few if they work out well!!
-steveo
steveo
Postby hunter » Tue Jul 20, 2010 4:14 am
doc i'm interested in getting on the list as well. my x5303 is all apart just waiting for your PCB boards. :)
hunter
Postby fechter » Tue Jul 20, 2010 8:41 am
The resistance losses (and therefore heating) are a function of current squared, so a 5302 is going to result in more heating for a given amount of torque, but will have a higher no-load speed.
Torque will be a function of (phase amps) x (number of turns).
Maybe a 5302/5304 dual wind would be good?
Those latching 60A air conditioner relays I found would be nice if they were SPDT. They do exist like that, but are expensive. To use the cheap SPST versions would take 9 of them for a series/parallel dual wind switch.
fechter
Postby tostino » Tue Jul 20, 2010 10:06 am
fechter wrote:The resistance losses (and therefore heating) are a function of current squared, so a 5302 is going to result in more heating for a given amount of torque, but will have a higher no-load speed.
I don't think that is actually true fechter... A 5304 has a resistance of 203.4 mohm, a 5302 has a resistance of 61 mohm (about 1/4th of the 5304). If you need double the current in a 5302 to get the same torque, the heating will still be the same in both motors for the same torque, but the 5302 will have a much better top speed.
A 5304 at 150 amps will make 4576 watts of heat.
A 5302 at 300 amps will make 5490 watts of heat.
Both motors should produce the same torque. If there is the same amount of copper in both motors, they actually should produce the exact same amount of heat. I don't know if this is just an error in the resistance numbers that I pulled from ebikes.ca, or what. But you get the idea.
tostino
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 4 guests
