ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL stator
Re: ELECTRIC TRANSMISSION DELTA /WYE and SERIE/PAPALLEL st
Postby liveforphysics » Tue Jul 20, 2010 3:37 pm
fechter wrote:The resistance losses (and therefore heating) are a function of current squared, so a 5302 is going to result in more heating for a given amount of torque...
No no no!
You shorten the wire by the same proportion that its thickened up. Shorter wire change in resistance of x, times thicker wire change in resistance of x, means x*x, makeing resistance drop at the square of turns, which balances perfectly with heat increasing at the square of current, to leave you with copper fill being the only thing that matters in determining the continous torque rate, and they all get identical heating for that torque value if the copper fill matches, etc etc etc...
The road of excess leads to the palace of wisdom
Experience is a hard teacher. First comes the test, then the lesson.
Best Lithium battery testing highlight video EVER!!!! :)
http://www.youtube.com/watch?v=dree0rTr1HM
liveforphysics
Postby John in CR » Tue Jul 20, 2010 4:06 pm
Wouldn't the exception to this heating issue during a given takeoff be that the efficiency of the higher turn count motor will increase faster and produce less heat? Also, since our controllers limit the current below the maximum the low turn count motor can take, won't the higher turn count motor have more real world torque as opposed to the theoretical equivalency? I believe the real benefits will show on steep climbs and during lower speed trail riding, where the higher turn count motor will have a distinct advantage by operating in its efficiency band while the low turn count motor is still trying to kill its controller during current limiting.
John
John in CR
Postby Doctorbass » Tue Jul 20, 2010 10:10 pm
Ok no.. again this debate... :roll: :wink:
Guys.. once i finished that PCB thing i'll try it and will post results and will see...
everythig i'm doing now for thst DH ebike need custom parts.. = welsing, laser cuting, cnc cuting, etc.. it take so much time to acheive!!! and guess what... it's vacancy period here so all industrial CNC and metal worker are 2 next weeks off!!! :shock: :x
I mist use imagination to finish that DH bike project before next monday!!! ( when i'll go to meet BlackArrow at 1000km fron here and by the time, see my familly)... The next days are crucial!!!
tomorrow night i should get the PCB, new torque arm/steel dropout, 12 lipo battery box and C-A... Alot of work to do . but that project will be the best to test the performances of that serie parallel method.. at high power!! :twisted:
Doc
________________________
ULTRAFAST DH ebike:
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec !! X5 5303 on 24"
-18 fets controller
-Peak power 18350W (23hp)
-24s 3p lipo
TORQUE SETUP:
-Succeded to haul a 19200 pounds schoolbus!!!
-202km range no pedal -
- 0-50km/h in 4sec!!
-100.8V 23Ah BATTERY made of 432x 18650 cell from Lithium Makita 3Ah 18V LXT -Team Konion™ Member
-Top speed 62km/h Torque 230lbs trust !!
Doctorbass
1.21 GW
1.21 GW
Postby John in CR » Tue Jul 20, 2010 10:29 pm
Doctorbass wrote:Ok no.. again this debate... :roll: :wink:
Doc
I hope you're riding the bike the 1kkm to meet up with BA. :?: That would be a great shakedown cruise. 8)
John
John in CR
Postby Doctorbass » Tue Jul 20, 2010 11:17 pm
Doc
John
Hey.. nice idea.. but with 1.3kWh of lipo i wold need to charge every 50km.. that's 20 stop... :shock: 20 stop x 45 minutes charge is 15 hours of charge plus the 20hour of continous run...... 35hour of ebike..
I should add some confortable spring on that DH seat and bring a sleeping bag with me..!
i'll pass this time.. Justin already prooven that long 7000km ride can be acheived.. i'll leave him the credit for incredible long ride!
Doc
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby Miles » Tue Jul 20, 2010 11:44 pm
It's not really a debate - more like countering the propagation of a common misunderstanding. :)
Miles
Postby BlackArrow » Wed Jul 21, 2010 7:20 am
John in CR wrote:I hope you're riding the bike the 1kkm to meet up with BA. :?: That would be a great shakedown cruise. 8)
John
Hi John,
Doc take his car to going here, but we have allot of quad trails here for his new DH ebike and he can test this series/parallel set up in this hostile environment :wink: . We can try to make some movie during those rides, and I'm really impatient to see and to ride with Doc, it will be fun no doubt about it :D
Good day!
Black Arrow
BlackArrow
Postby fechter » Wed Jul 21, 2010 8:39 am
Sorry :oops:
Yes, for the motor I see your point about fill, but losses in the phase wires and conduction losses in the FETs will still increase.
I'm reminded of the Ecycle 'Solid Slot' configuration where it's like just a big bar of copper in each slot. If properly driven, seemed to remain pretty efficient.
The key to that system was using a dedicated inductor for the PWM instead of using the motor windings. With very low turns, the inductance of the motor gets pretty low, which you could counteract by using a higher PWM frequency. Motor windings tend to be pretty lossy at higher frequencies (mostly core losses), so they added a high quality inductor/freewheel diode ahead of the motor. Supposedly the lossed avoided in the motor windings more than made up for the losses in the separate inductor.
Long story short, with 2 turns, you might see some improvement if you added some kind of inductance in series with each phase wire.
fechter
Postby John in CR » Wed Jul 21, 2010 9:47 am
Sorry :oops:
Like what?....Do some smallish loops of our phase wires? If so, how many might do the trick?
John in CR
Postby Doctorbass » Wed Jul 28, 2010 2:25 pm
The motor serie parallel mod is finished!!!
Now i'm working on the controller and battery.
i'll post results soon!! :mrgreen:
DOc
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby rkosiorek » Thu Jul 29, 2010 6:19 am
Good to hear Doc! can`t wait to hear your experiences.
i think that you will only be using the high turn count mode only briefly during hard launches. most of the time you will be in the low turn mode.
rick
DISCLAIMER:
We will not be responsible for damage to equipment, your ego, blown parts, county wide power outages, spontaneously generated mini (or larger) black holes, planetary disruptions, or personal injury that may result from the use of this material.
- Samuel M. Goldwasser -
rkosiorek
Postby steveo » Thu Jul 29, 2010 10:30 am
I hope doc attempt is better then mine lol...
-steveo
http://www.youtube.com/user/trdfreak03
Infinity Titan Bike/24 mosfet irfb4110 @ 200 amps - 20hp+/24" x5306 New Gen Crystalite/24s 4p A123 Battery/45k/h top speed/ torque demond
New Build Supercycle/18 mosfet irfb4110 @ 175 amps/x5303 20"/ 20s 4p a123/
you've tried the rest .. now try the best!
24 mosfet/18 mosfet/12 mosfet 100v IRFB 4110 controllers for sale. Pm if interested
steveo
Postby Doctorbass » Thu Jul 29, 2010 2:05 pm
It's ALIVE !!! 8)
Motor mod done and it work!!!
I just need to assemble the 12 lipo + BMS in the battery case for 88.8V 15Ah.
No load speed at 100V(psu);
84km/h serie mode
99km/h+ ( CA reading max :lol: ) but i expect to be around 170km/h
here is some preview for those who can't wait for the 100+ pics i took and will post soon:
Dont worrie, the little 9 conductor flat is soldered without any short and now is poted in epoxy!!
Pics 001_800x600.jpg (136.59 KiB) Viewed 186 times
Pics 002_800x600.jpg (105.04 KiB) Viewed 186 times
Pics 004_800x600.jpg (120.46 KiB) Viewed 186 times
Pics 013_800x600.jpg (80.94 KiB) Viewed 186 times
Pics 018_800x600.jpg (61.79 KiB) Viewed 186 times
Pics 026_800x600.jpg (91.74 KiB) Viewed 186 times
Pics 027_800x600.jpg (78.02 KiB) Viewed 186 times
Pics 030_800x600.jpg (115.38 KiB) Viewed 186 times
Pics 041_800x600.jpg (101.41 KiB) Viewed 186 times
ULTRAFAST DH ebike:
-18 fets controller
-24s 3p lipo
TORQUE SETUP:
Doctorbass
1.21 GW
1.21 GW
Postby rkosiorek » Thu Jul 29, 2010 2:39 pm
wow that is a heck of a lot neater than what i ended up with doing point to point wiring. i think that you have proven that this is the way to go if you are going to do it.
how heavy is the copper on the board. was the board etched? or did you just CNC the traces and cutouts for the relay leads.
I WANNA SEE IT RUN> < I WANNA SEE IT RIGHT NOW!!!!>
rick
ps. good looking bike by the way. and i hope you didn't notice, but i have some minor issues with impulse control. leastways thats what my lawyer called it.
DISCLAIMER:
rkosiorek
Postby steveo » Thu Jul 29, 2010 8:39 pm
Doctorbass wrote:It's ALIVE !!! 8)
84km/h serie mode
i gaurente 70mph+ @ 120v!
one word.,,,
AWSOMENESSS!!!!
-steveo
steveo
PreviousNext
Return to E-Bike Technical
Who is online
Users browsing this forum: ebikepimp10 and 3 guests
