Would this RFID ignition switch work?
BerkshireEbiker
Post by BerkshireEbiker » Dec 31, 2017 9:49 pm
Hello everyone and a happy new year to you all
I have a DC to DC converter, and I came across this on eBay and wondered if it would work in replace of my key switch. Here's the eBay link
https://rover.ebay.com/rover/0/0/0?mpre ... 3342194748
Thanks in advance
amberwolf
Re: Would this RFID ignition switch turn?
Post by amberwolf » Dec 31, 2017 11:25 pm
I doubt that the switch would actually turn.
If it can handle the full voltage of your battery, or if it can switch an external relay, then it'd probably be able to act as a keyswitch replacment (assuming your keyswitch is like many and switches the battery voltage to the MCU side of a controller. If yours is different you'd need to know what the keyswitch actually does and determine if this one will do that).
There's some stuff here on ES that might be easier to use, if you look up
RFID
(especially in thread titles, and display by topic).
BerkshireEbiker
Post by BerkshireEbiker » Jan 02, 2018 1:40 am
RFID
Thank you for you message Amberwolf. I found another one eBay with may work better. What dose everyone think?
https://rover.ebay.com/rover/0/0/0?mpre ... 1480136209
