dogman dan said:Cut an inch off the lever would shorten the throw.
dogman dan said:Or just go to the type most end up liking best, half twist.
ferret said:Maybe combine a short "vertical" travel throttle with this product (or DIY somthing similar):
http://www.wolftoothcomponents.com/products/remount
Avner.
We do not recommend the ReMount for multi-chainring drivetrains (it sits where your front shifter does)
teklektik said:Or get a CA3 and set the 0-100% throttle output to be any fraction of the throttle throw that you want...
fechter said:Depending on how your existing throttle is built, it may be possible to modify it for a shorter travel, either electronically or mechanically.
fechter said:but it may work to simply cut (break) the magnet in half to get half the throw.
MrDude_1 said:all you need to do is cut the magnet with a dremel and a cutoff wheel. that makes the electrical throw shorter.
fechter said:It's a little complicated to explain and not all throttles do it the same way.
Basically, one end of the magnet is south and the other end is north. Right in the middle, the flux will be zero to the hall sensor.
If you cut the magnet in half, it will still be south on one end and north on the other end and zero in the middle, just over a shorter distance.
Buk___ said:fechter said:It's a little complicated to explain and not all throttles do it the same way.
Interesting. It shouldn't be too hard to test that.
And if it doesn't work out well, putting the two halves of the magnet back end to end would be back to status quo. (I think?)
MrDude_1 said:the magnet is very brittle and hard to re-connect once broken.
Buk___ said:MrDude_1 said:the magnet is very brittle and hard to re-connect once broken.
Wouldn't the two half just stick together? North pole to south.
MrDude_1 said:Buk___ said:MrDude_1 said:the magnet is very brittle and hard to re-connect once broken.
its not strong enough to stay together that way inside your throttle. this isnt a very strong magnet.
