Regen with a BMS that has separate charge port
rg12
Post by rg12 » Jan 02, 2018 6:35 am
Hey Guys,
Just thought about something.
First of all, what happens if you charge a pack that has a separate channel for charging through the discharge wires?
AND, if it is not recommended, how will regen work without damaging anything?
Mongoose EC-D 2007 (19" motocross wheels), 21s 10Ah LiPo, Greentime 72V 80A Controller, 12kg Hub Motor
cycborg
Re: Regen with a BMS that has separate charge port
Post by cycborg » Jan 02, 2018 9:28 am
You can charge through the discharge port - the problem is that the BMS won't cut off charging if a cell hits HVC, so you have to monitor your cell balance and terminal charge voltage. There's no problem doing regen through the discharge leads, as long as you don't start fully charged at the top of a big hill, and you limit the regen current to a safe level.
rg12
Post by rg12 » Jan 02, 2018 11:09 am
Oh, thats good to know, thanks alot :)
