Hello team, I need a hand. It looks like I'm so close to having this setup working, but not quite.
I have - Q100H, S06S, S-LCD5, a throttle and a PAS sensor powered by a 24V battery.
What works - everything except the PAS assistance. I tried following the wiring diagram linked on the website, but the wire colors don't match at all, nor the connector count. With a multimeter and thru a process of elimination I identified the following:
* AC phase and DC - easy
*the 6-pin goes to the motor HALLs
*many pin connector to the S-LCD5
*throttle 3-pin identified with a multimeter as it's the only one that goes 5-GND-signal (as opposed to 5-S-GND)
*I think I have the brake sensors, as whenever I connect a spare PAS to them (I have no brakes) the whole system cuts
Here are some pics of the wiring as it is now.
https://photos.app.goo.gl/wdTjYc26KLxLI96n1
My questions would be - is there a real S06s wiring diagram somewhere, or do you know - which connector should he PAS be coupled to and if the PAS function needs to be activated somehow? On my old infineon 4110 setup I need to short two pins to activate PAS, maybe here too? I don't want to short the controller while testing, I bet there are many having been thru this already...
Thanks in advance
*EDIT: I browsed the LCD manual and it seems there should be an ASSIST indicator if the function is active - I find no ASSIST on the display of my LCD5: https://photos.app.goo.gl/78FfK3FyK9Eprv5J3
Thanks in advance
