canyondancers1
- Joined
- Feb 8, 2018
- Messages
- 2
i was plugging battery back to motor after charging noticed a larger sound then usual. i have a 48 volt 1500 watt hub motor. when i turned lcd on i noticed that i could not change the ...(not sure of the correct wording) but it is the button that controls the amount of power that is available to motor power (wattage / voltage). I cant get into settings. I also cant increase the power above 1 limiting the bikes power. Is it the lcd or the controller? kinda stuck on trying to figure out. When inspecting i noticed that i had forgotten to add a fuse. I realize that this was a bad mistake. The bike is still rideable takes a bit longer to get to higher speeds. I have since added the correct fuse, alittle to late but it is a lesson not to be forgotten. I do have a 48 volt 1000 watt controller and lcd, can that be used until i can replace with an upgraded one?
